Old 10-26-2022, 05:05 AM   #2
stidnam
Drives: Starlet
The part number you have looks correct. The picture does not look the same as other Toyota manuals, but the part number seems to match. It's also known as COVER, ENGINE UNDER, RH.
There was a different part number for 04/2014 onward for 2014 models. FYI. If you go to the parent image in your link you'll see another part called COVER, ENGINE UNDER, RIGHT with part # 51441-52330. That's the 04/2014 on part number.
I dare say the belt you're talking about is the V belt that runs the AC, water pump and alternator.
stidnam is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
