Old 11-05-2022, 07:44 PM   #3
sh0rtlife
well i can now say for sure a sedan uses a different REAR regulator than a 5dr.....
anyone know if right and left are the same in the rear?.....i know up front they are "close" like the clocking of the main arm is off by only a few degrees as in you can install them on the wrong sides with the correct left/right motors on them and it functions but wont go full travel up....
in theory the rears could actualy be the same part with just a different motor on them as they dont rely on needing the 3rd arm....but i have yet to lay my hands on a driver rear to find out
Driver's power window auto-down disable? yaris07hb DIY / Maintenance / Service 6 04-01-2019 06:07 PM
FYI: Aftermarket parts from Japan (NCP131) yarisugi Third Gen Yaris General Discussion 26 01-30-2016 06:43 AM
Power window noise birdman DIY / Maintenance / Service 10 09-01-2012 12:11 PM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 06:27 PM
