Old 11-06-2022, 10:36 PM   #1
yaris2014toyota
Drives: Yaris 2014 2-Door LE
fuse - type needed, plus interior fuse box cover missing
2014 Yaris LE 2-door Liftback here.
My car is going to need some new fuses, it seems.
Two questions:
  1. Would this car use Standard or Mini Blade type fuses?
  2. The cover of the interior fuse box is missing (here's a link to an equivalent thing in a different model of Yaris). Given that my cover is missing, where can I now get an accurate schematic of which fuse is located where, please? And where can I get a replacement cover, please?
Thank you in advance.
yaris2014toyota is offline   Reply With Quote
Old 11-07-2022, 12:18 PM   #2
thetut
Drives: 2007 4dr sedan
Does this help? https://www.startmycar.com/ca/toyota...anchorfusebox1
thetut is offline   Reply With Quote
Old 11-09-2022, 05:11 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Driver's kick panel uses low profile mini fuses.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 11-14-2022, 12:51 AM   #4
yaris2014toyota
Originally Posted by thetut View Post
Very helpful, thank you!
Old 11-14-2022, 01:29 AM   #5
yaris2014toyota
Thank you. I have ordered a box of assorted low profile mini fuses.
How about the fuses in the hood. What sort of assorted fuses should I order so that I always have potentially needed fuses on-hand? Would those be Mini Fuses (non-low-profile)?
Old 11-14-2022, 01:57 PM   #6
thetut
In the site that I quoted you can scroll up and down to the other fuse boxes and it will show the type and size of the fuses in them.
Old 11-14-2022, 07:57 PM   #7
yaris2014toyota
Ah, good idea.
(Also an update: I swapped out a non-working low-profile mini with one from the box of assorted low-profile mini fuses I had ordered from Amazon, and the cigarette lighter started working again. My first time swapping out a fuse, and it felt good!)
Old 11-15-2022, 02:14 PM   #8
thetut
There you go!
Custom Lift Back Hidden Sealed Woofer Box TinyGiant DIY / Maintenance / Service 42 04-15-2010 04:36 PM
DIY: Custom Hidden Trunk Box (08 Yaris 3D) goku87 In Car Entertainment + Electronics (audio / video / alarm) 0 10-19-2008 06:43 PM
TRD Tissue box cover YarisSedan Cosmetic Modifications (Exterior/Interior) 6 10-19-2008 01:48 PM
fuse box confusion! kroxychc In Car Entertainment + Electronics (audio / video / alarm) 3 08-31-2007 09:49 PM
**CUSCO Type OS strut bars** C2AUTOSPL Sponsors Classifieds Area 12 08-04-2006 11:35 AM
