no go by a good bit, and to clear id need atleast 1 inch of spacer possibly more
plan B with the wheels is to see about having them cut out and turned into a 3 piece wheel at which point minimum size would likely be a 15 possibly even 16....having 100$ into the set i see it as a viable future for them i can say with fair amount of certanty that most any 13inch STEEL wheel will fit and maybe even some 12's as far as 13inch aluminum goes its going to all come down to the exact placement of the "well" in which the beeds get dropped down into when mounting and dissmoutnting a a tire..if the well is neer/on the face then a 13 should fit..the further inboard that "well" is the more spacer that will be required all said if there was a way to gain about 1/4 inch they would "just" clean but be terrifyingly close to the caliper |
| Are 13s possible with a 1nZ-Fe | crazylegs | Performance Modifications | 4 | 02-17-2016 10:10 PM |
| pittsburgh 13's | djhuddy2442 | Tracking, Racing, Auto-X Forum | 0 | 10-29-2014 09:05 AM |
| Ansen Old schol mag 13's with sumitumo tires! | crankyelbow | Items for Sale by private party | 24 | 05-02-2010 04:49 PM |
| 13's ? | 03Z33 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 67 | 03-17-2010 09:14 PM |
| 13's....Anyone on NCP91? | Penguin Garage | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 89 | 07-29-2009 11:56 AM |
