![]() Drives: 2010 Yaris 4 door hatch Join Date: Oct 2022
Where are you located? I’d buy all the parts for the manual you won’t need with the auto. Clutch/brake pedal boxes, shifter and surround, shifter cables, brake and clutch master and the lines. If you’re interested in selling them that is. I’d have some things I could give you as well. Auto shifter and surround brake master etc. basically swaping the manual parts for the auto parts.
| Tags |
| 1nz-fe, 2nz-fe, conversion, swap, transplant |
| Auto or Man Transmission? | bad | General Yaris / Vitz Discussion | 3 | 03-01-2022 03:58 PM |
| Yaris MPG falls to 31 (auto) 32 (man) under new guidelines | deebrown | General Yaris / Vitz Discussion | 30 | 06-26-2007 03:18 PM |
