Old 02-10-2023, 08:05 AM   #10
BennyLava
Drives: 1987 Silverado
Originally Posted by remcafee View Post
you can also buy new oem seat covers, remember that every single part on your toyota can be fixed
Yes but some of the aftermarket covers will have a small layer of foam on the underside. This helps a bit if the seat is somewhat worn. Granted you should probably glue down some seat foam before you put on the cover, if this is the case. 1 layer of half inch or 3/8" thick seat foam would go a long way. It would make the cover look nicer and fit better too.
BennyLava is offline   Reply With Quote
Unexpected Seat Belt Light Flashing ern-diz DIY / Maintenance / Service 19 09-23-2018 01:03 AM
DIY - Replacing the Front Seat Cushions CTScott DIY / Maintenance / Service 6 10-04-2016 06:39 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Drivers seat - wire sticking through cover on back. azeeroth DIY / Maintenance / Service 1 03-30-2013 10:37 AM
