Old 03-13-2023, 04:04 PM   #73
sh0rtlife
cant lower.....roads wont allow it ..chins allready take hits as it is and im not talkin about just driveways but actual dips in the back roads
Old 07-15-2023, 03:17 AM   #74
Compeer
Drives: NCP90 TRD Yaris Manual
I am back using the TRS sportivo suspension currently, thats pretty close to stock height and rides nice, the springs could work good for you and are still around, little stiffer and tiny bit lower? I guess tho you have snow to deal with.
Compeer is offline   Reply With Quote
Old 07-19-2023, 02:23 AM   #75
sh0rtlife
eh snows not the issue to be honest..and the snow tires are as tall as i can fit
its the roads i go burn up that are the issue....the super fun twistys have alot of odd dips n such, but were talkin twisty mountain roads that run like a rollercoaster...so youll hit hard dips and the chins will scrape....im at stock hight ..stiffer springs would help a little..so a tiny drop with some stiff would be fine
Old 08-20-2023, 08:11 AM   #76
Compeer
I see the springs come up for sale quite a bit here
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 02:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-24-2017 11:26 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
