Originally Posted by Binks
Ended up biting the bullet and got some avid1 av-08s with 195/55r15 yokohama advan flevas! Very Excited to see how it looks, thanks guys.
Gonna be a bit taller of a setup but I dont think it should rub and I got some camber bolts that should make it safe.
How accurate is your speedometer with the 175/65 R14 tires?
I was going to say don't worry too much with the 195/55R15 tires being a bit taller. One of the OEM wheel/tire combo is 185/60R15, which is taller than what you picked, but would make you go faster (about 2MPH) than what's indicated by your speedometer if your speedometer is dialed for 175/65R14.
