Old 03-21-2023, 06:48 PM   #7
sh0rtlife
most modern belts are made for a "spring tension" setup and no longer are made with any real "stretch" in them..which is what you need for a "fixed" tension setup like out yaris....i run into the same problem, so i re-adjust for winter and summer
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 06:19 PM
Drive Belt Replacement wagon DIY / Maintenance / Service 2 12-28-2014 11:24 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
