![]() Drives: Yaris Mk2 Join Date: Mar 2023
Brake caliper rewind tool for rear brake piston
Looking for a Brake Caliper Rewind Tool that fits rear brakes on Yaris MK 2.
Any tips on dimensions of the piston or cheap tools that fits? Thanks! |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
C-clamp and a piece of wood
#5 | |
Tools are cheap enough to buy. Better yet, maybe some of your automotive supply stores have a loan-a-tool program. Needle nose pliers will work but may involve some colourful language in your part.
My apologies. I've never actually done the brakes on my Yaris. The C-clamp method has worked on everything else I've worked on so it was my default option. Please ignore my advice.
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
sst and sst only! needle nose pliers are not a good idea, you will scratch up the surface of the piston
Google brake cube tool.
Thanks for the feedback
![]() Got the cube on eBay. Will update on the success. |
having just done the xb2 a few weeks back i can tell you 2 things, you need to push a a lil as you turn it and you need to verify the direction of rotation...not all of them are clockwise
with that said i had to turn one both directions to "free" it up so it would finnaly actualy thread in, and found that too much pressure and it wont, too little and it will just spin in the end tho i didnt need a tool..tho the xb ones have nice grab notches on the edge of the piston so you can pretty much do it by hand |
I did put the order on hold due to a question:
I have a manual old fashioned hand brake (no electronic parking brake or park button). Do I need a rewind tool then, or is that just for the electric motor in the e-brake? |
The electric parking brake systems have to be put in service mode with a scanner then the piston usually get compressed straight in. Use the cube to wind in the older style calipers.
if youve got a hand brake youll like having the tool, not everyone needs it, but when you do youll wish you had it
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| MOVED - Brake caliper rewind tool for rear brake piston | Mightymoo | General Yaris / Vitz Discussion | 0 | 03-24-2023 07:24 AM |
| "Thunk" sound after caliper and brake pad replacement | Hamster | DIY / Maintenance / Service | 3 | 08-22-2020 10:34 PM |
| New brake caliper installed | 06YarisRS | DIY / Maintenance / Service | 2 | 08-21-2020 10:35 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
