Old 09-07-2023, 03:59 PM   #3
Since the Yaris is basically bullet proof, there should really be nothing to be overly concerned about. Look for signs of leakage around the water pump. That has proven to be the most common component to prematurely fail.
Bitch about the clear coat. That's like a cancer whose spread cannot be stopped once it's taken hold.
If you're impressed with what you see and are seriously willing to pull the trigger, spend a few bucks for an inspection. Will put your mind at ease, and may provide some bargaining points if wear and tear items are required to safety it.
