![]() Drives: 2012 Base Sedan Join Date: Aug 2023
CV axle c-clip not engaging
Install of cv axle driver side after reboot and replacement of oil seal.
The axle seems to go in all the way. The frontal aspect of the oil seal is now impressed or dented by the forward edge of the axle’s dust cover. Neither the new or used c-clip appear to engage. The axle can always be pulled out pretty easily. An unidentified square steel bar, about 10mm wide, extends on a figurative clock, from about 1:30 to 7:30, within the transmission, beyond a meaningful gap. The gap begins at the point where the lands/grooves engaged by the axle end. After multiple attempts at seating the axle, nominal scratches, a pair of arcs, now appear on the bar. The marks appear to correspond to the end of the axle. So it seems the axle can go in as far as it will go, and that it has. I’d appreciate any thoughts on this matter. Thank you for reading. |
One time, a few years back, some members and I were doing a suspension swap. I remember that if we allowed everything to hang slack once the strut assembly was removed, the axle would just fall out.
The bar you're talking about is the carrier cross pin. Not easily removed and not necessary either. I'm not sure why the clip isn't engaging or is it enough and you think it's not.
Yes, everything is slack. I have been engaged in replacing the front end, brakes, and odds and ends like engine mounts. And painting rusty parts with high temp paint or POR-15. The thing to do here, then, is to put everything back and see what happens. Its often the case an effect exists, which may include the loose axle wee yari describes, even if we can't see why. The effect exists, may be able to resolve it without knowing why.
Also, the identification of the bar as the cross carrier pin by ex-x-fire. Now I can figure out what it does and see if maybe something like the axle cup holding the bearings is set back too far, or suchlike. Maybe I missed something. If the axle is never supposed to come close to that pin I might learn something there. I'll write up what happens, there's good reason for it. I've been lucky. I might have damaged that pin if I had pounded harder or used a heavy hammer. Thanks again. |
What this video. The carrier and cross pin part is at around 14:00. https://www.youtube.com/watch?app=desktop&v=JGbsgpp2YJQ
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Do you have any pictures?
Follow up to CV axle c-clip not engaging
It appears to me to be the case that when the engine is lowered to some degree, the cv axle comes out rather easily. I raised the engine and rebolted the motor mounts, and the cv axle seemed completely normal. I have since driven some miles and there are no known issues.
This strongly implies that when cv axles on these cars are frustratingly difficult to remove, lowering the engine a bit might be a valid option, one that may be superior to special tools or some of the more exotic DIY methods. cclip Thank you very much. |
| Tags |
| c-clip, cv axle |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| Clip remover tools not working, mangling clips | RMcG | DIY / Maintenance / Service | 6 | 01-29-2021 11:31 AM |
| TRD Delrin Rear Axle Bushing Collars | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-15-2019 07:50 PM |
| Request: Picture of the transmission end of passenger CV axle | WildChild | DIY / Maintenance / Service | 2 | 06-16-2014 12:35 PM |
| MI SSK In-Cabin DIY (Golddeenoh) | BEEF | DIY / Maintenance / Service | 5 | 03-26-2013 01:19 PM |
