Old 06-07-2024, 02:44 PM   #2
AYaris07
Drives: 2007 Yaris Hatchback
Update: I forgot to add that when you put the screw back in the hole nearest the instrument panel, there is very little room. I used a little white tack on the head of the screw, and using my index and middle fingers started the screw in the hole, then you can cinch down with your right angle tool. The screw closest the passenger door is much easier and can use a regular screwdriver to tighten up after using your fingers to start the screw in the hole.
AYaris07 is offline   Reply With Quote
upper glovebox door
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
