What oil spec do you use?
I would start with compression measurements for all cylinders. If they are more or less the same and on the lower numbers of the spec, you can try using one degree thicker oil. That usually helps with better piston sealing and lowers the oil consumption. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Wiper Motor rear | k3nty | DIY / Maintenance / Service | 15 | 08-24-2014 09:07 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
