All I can ask is what's failing on the water pump? The seal or is the bearing loose. Figure out what's squealing. Is it another pulley making the noise because it's locked up? A/C compressors sometimes can lock up when the a/c is activated. This can happen when the defrost is turned on.
| water pump lifespan | esse10 | DIY / Maintenance / Service | 15 | 04-13-2026 12:57 PM |
| Fuel pump upgrade... | Neinris | Performance Modifications | 31 | 12-16-2024 03:27 PM |
| 2007 - Water pump suggestions | littleblackyaris | DIY / Maintenance / Service | 1 | 10-04-2020 08:51 AM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 08:55 PM |
| Location of Water Pump | lululovesu | DIY / Maintenance / Service | 1 | 10-19-2014 08:05 AM |
