Old 02-14-2025, 12:03 AM   #1
Tigger's Dog Rescue
Drives: 2008 Toyota Yaris
Block Heater Cord
My block heater cord was damaged at the plug in end that sticks out at the bottom of the grill. Where do I find a diagam for the engine, so I can replace it.
Thanks
Tigger's Dog Rescue is offline   Reply With Quote
Old 02-15-2025, 11:25 AM   #2
Gdawgs
Drives: 2010 Yaris
I'm not 100% sure with Yari, but typically block heaters are an aftermarket item that dealers/shops install(or DIY).
Trace the cord back and find the heater then see if it's the type where the cord can be unplugged from the heater. If so, you can purchase a similar heater with the cord, and just replace the cord. I've done that a couple times(not on a Yaris, but other vehicles). I've never had a Yaris with a block heater.
Gdawgs is offline   Reply With Quote
Block heater IronYaris DIY / Maintenance / Service 1 09-10-2020 03:22 AM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Yikes, thats an expensive block heater HDS DIY / Maintenance / Service 2 12-17-2009 07:30 AM
