Old 04-02-2025, 04:17 AM   #4
Sabina
Drives: yaris
Yes, what you experienced with your Timken wheel bearings is normal. Many modern front wheel bearings, especially split inner race designs, rely on the axle nut to properly seat and eliminate play.
Sabina is offline   Reply With Quote
Wheel bearing problems Doobiejack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-29-2024 08:59 PM
Wheel bearing wobble? BennyLava DIY / Maintenance / Service 10 05-18-2018 06:11 AM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
