Drives: 2014 Yaris LE (4 door) Join Date: May 2015
2014 SE: Parking Brake & Reverse Light Wires?
I'm installing a new head unit. I have everything all set up, except for the reverse light wire connection (for the backup camera) and the parking brake wire connection. I don't know where to find these. Anybody know? Thanks!
Oops...LE (not SE). ETA: Solution (in case anyone else runs across this)... The wires are in the lower dash on the driver side/left side. To get to it you have to remove the lower dash cover by the trunk open button/lever. I used plastic dash removal tools. It seemed hard to remove at first, but there are no screws or anything. It just snaps in in a couple of spots much like the stereo dash cover. There are lots of wires on the left side. Those are the ones you want. The white wire harness with the black edge/clip that's on top has the reverse light (the red wire 8 pins down from the top left). Note there are multiple red wires in this harness, so make sure to the the 8th wire one from the top left. According to the instructions I followed, it's technically pin 28 in the 56-pin white plug (3A) at the rear of the dash fuse box. The white wire harness with the gray edge/clip directly below the above wire harness has the parking wire (the red wire 8 pins down from the top left, it's the only red wire in the harness). The instructions I followed say it's the red wire in pin 28 of the 36-pin white plug (3D) at the rear of the dash fuse box. Last edited by canaws; 09-06-2024 at 10:05 PM. Reason: Added solutions |
Drives: 2017 Toyota Vitz hybrid Join Date: May 2025
Thanks this worked for me 2017 Vitz Hybrid . Right hand drive so plug is behind the glove box. Reverse trigger is 8th wire down on left - red (33). Image is reversed as you are looking at the plug from the back. This is how it looks in the car.
| Advice on replacing a rear brake light bulb | RMcG | DIY / Maintenance / Service | 17 | 06-05-2022 06:48 AM |
| ABS BRAKE light FIX sedan | IndestructibleYaris | DIY / Maintenance / Service | 4 | 11-27-2021 01:35 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 03:09 AM |
