Old 03-22-2023, 03:36 PM   #1
Darren
Drives: 2007 Yaris Rs 442000km
Question 2007 Yaris RS hatchback 5 speed, speedo tach not working
Please help!!! I removed the cluster from the dash to clean it, had so much dust I could barely see through! Everything worked properly beforehand. Now when I put the key in the ignition both speedo and tach drop and don't go to zero they function but are off. After they drop I can zero them by hand before I start it and all is good until I turn the ignition off and after 3 minutes or so you can hear the computer click and turn off at that point it starts all over with the gages dropping upon putting the key in. I went to the dealer because I thought that maybe it needed to be reprogrammed or zeroed they said no... I really hope I didn't break it. I will take a video and attach it if I can.
Darren is offline   Reply With Quote
Old 08-18-2025, 08:35 PM   #2
jpzitz
Just got this thing😭😭😭
Drives: 2007 Yaris 3d hb base
I cleaned my instrument cluster and desoldered an LED on the circuitboard, my speedo isn't working at all but everything else is. Will I have to replace the entire cluster, or just get the servo replaced perhaps?
jpzitz is offline   Reply With Quote
cluster, speedometer, tachometer
FS(NY): 2007 Toyta Yaris Hatchback mr_robot Cars for Sale by private party 3 08-31-2018 12:31 PM
$700 2007 Yaris 2DR Hatchback hodginsa New YARIS Purchase Forum 63 11-12-2017 11:36 PM
Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback AndyW Willing to Buy by private party 6 12-07-2014 08:53 PM
