info about clutch
i want to know the difference between the 2 clutch of zpi
http://www.zeropointindustries.net/s...roducts_id=321 and http://www.zeropointindustries.net/s...roducts_id=320 i know one is for street and the other for racing... but what is the difference in the mecanic of these 2 clutch.. |
Look slow, go fast
Drives: 2007 Yaris Liftback 5 spd Join Date: May 2007
The racing clutch should be more on-or-off with less room to slip than the street clutch. It will probably be harder to engage it smoothly and not ideal for street use. It would probably last longer, but I doubt there is ANY difference in real life between the two because the torque and horsepower numbers you'd see from even a turbocharged Yaris (what, 160-180hp?) shouldn't challenge the holding power of the stock clutch.
Daily Driver:
Toyota Yaris Hatchback, 5spd. Go-fast: 1995 Chevrolet k1500 extended cab Blown 396 smallblock 797hp @6500RPM looks stock, but burns riced-out imports daily. |
the stock clutch, can't hold the power of the turbo kit. It will start slipping immediately. As for the differences, Sleeper is right the 6 puck has a much more aggresive hold and is less streetable. It can still be used but for someone that wants more of a stock feel, the street disc is the way to go. If you like ripping up the clutch i.e. doing a bunch of burnouts and the like, I would recommend the pucked style.
#4 | |
Look slow, go fast
I remember my stock clutch in my pickup was good for ~475HP, after that it started to slip under hard acceleration (and the clutch had 20k miles on it too). That's 2x the stock horsepower of my truck. Muscle cars and big trucks have gotten me used to stock parts that can take a beating. I'm going to try a couple of high-RPM clutch releases today and see if I can get the stock clutch to slip. If it does, I'm going to be disappointed. I've never experienced a new clutch (i.e. not completely worn) that can't take a mere 100hp and 100lb-ft of torque. Duct tape could hold the clutch plates from slipping with those numbers.
Daily Driver:
#5 | |
![]() ![]() Drives: 07 Yaris LB, 70 Mach 1, 84 5.0 Join Date: Feb 2007
Man, I'm on fire tonight. Just being an ass in everyone's thread. Sorry.
well since clutchs are actually rated for torque not HP, I couldn't tell you what stock torque is like. I can tell you that the clutch is manufactured as said for an economy car, that being said the emphasis was probably on comfort over performance, which describes the soft cushy pedal feel. It isn't unheard of to have to upgrade clutchs, on most sport compacts once power is upgraded so too must the clutch.
Look slow, go fast
I don't remember the torque numbers for my truck engine when I replaced the clutch, so I gave the HP. I realize that clutches are rated for torque, but at what # does the Yaris clutch start slipping since stock it only has 100lb-ft? What torque numbers are you seeing with your car turboyaris?
Daily Driver:
184 ft lbs i mean again its isn't a huge increase but you have to do it more as a percentage then actual numbers. Most clutches on sport compacts and all hold to like a 30% increase i believe. I can't say for sure where you would start slipping, supercharger, you might be able to get away with, but not the turbo kit.
![]() ![]() Drives: Scions Join Date: Feb 2007
The racer clutch will be a little more aggressive this includes pedal feel. It is still a sprung hub so it is not instant engagement like one might think. It will take a day or two to get use to it but can be driven everyday.
Either clutch will hold the power, the racer clutch will withstand more abuse longer.. i.e. hot lapping at a race track. The street clutch may subdue to heat if you where to beat on the car for an hour straight or something. |
| 07 clutch burning? driver or design? | kennywhy | DIY / Maintenance / Service | 22 | 10-01-2009 01:03 AM |
| Hard clutch pedal ? | hystria | General Yaris / Vitz Discussion | 5 | 05-11-2007 06:12 AM |
| Clutch Start is TOO DEEP | ricepower | DIY / Maintenance / Service | 16 | 03-18-2007 03:02 PM |
| c one motorsport clutch line(pics) | badhabitz | Performance Modifications | 6 | 07-31-2006 10:08 AM |
| holy sexy clutch | birdy | General Yaris / Vitz Discussion | 8 | 05-05-2006 08:34 AM |
