#19 | |
![]() ![]() Drives: 06 Yaris RS MT Join Date: Jun 2018
#20 | |
#21 | |
The fic seems to be in control even in closed loop, actually too rich for my liking, was seeing 13afr around 3k rpm 120km/h on the highway, will record with techstream later on... I'm still experiencing hiccups sometimes, mostly on hard pulls, right after shifting, getting into 2nd or 3rd gear. Have to make fuel and maf adjustments on high rpm gear shifts. Waiting for my wideband, the fic is great after all. Btw I had a crankshaft position sensor code at 1st with z007 firmware, flashed it to z0100 and works great, only codes I've seen since are; maf performance and sensor1 bank 1 too rich... |
#22 |
I'm really glad you're making progress with the F/IC. Maybe when you're done tuning, I can try your map for fun to see how it works in my car. Have you done anything with your 02 map?
#23 | |
Haven't made the o2 map yet, have to install the wideband. Need to take everything out to weld the o2 bung, should have done it before. I'm still having issues with the maf map, I don't have any maf voltage/rpm data so I'm just guessing here... |
#24 |
Hey Jeff. How are things? Any developments on your build? I haven't done much to my car lately other than taking it out into the driveway for warmups. I picked up a double flare tool and tube bender. Thinking about converting my transmission cooler hoses to steel.
#25 | |
He concluded that my turbo is most likely the culprit. I think he's right, the turbo probably got damaged whenever my oil return tubing unplugged from the block and I drove it slowly less than a km with almost no oil since I was close to home. Just took the turbo out yesterday and there's a loose ring, will swap it out later on today. And I'll look into the camshaft sensor, I'll either add a 2.2k resistor or unplug it from the fic. 20210620_141334.jpg |
#26 |
Update
I swapped the turbo cartridge and it was still not boosting, and it looks like the loose ring is normal as I inspected 2 other 13t cartridges and both have the gap shown in the previous post. Finally today it occurred to me to have a look at my maf map and saw that it was all zeros, I uploaded a file I haven't ran since last August and BAM, finally have boost again! I felt really stupid, but I guess that's part of learning, this project was getting me very frustrated.... I have the 2.2k resistor between the crank wires and disconnected the cam from the fic like 06YarisRS suggested, running z107 firmware and so far everything seems ok. At least now I have something to play with this summer... Back to fiddling with the fic maps... |
#27 |
2ZR swap. DO IT! Ask how!
Funny how the little things will trip you up, eh? Glad to hear that you're making progress!
#28 |
Yes! Great to hear that you're making progress! We're in the process of moving, then some renos. Hope to have part of the summer to enjoy my car. When time permits, it would be great to compare tunes and see if we can learn a bit more about how to fine tune the F/IC.
#29 | ||
I was blinded by anger, I almost took everything apart. Quote:
Have fun with your new property! |
#30 |
Some pictures
Here's a few pictures.
Have been busy and didn't do much with the project. I still have a few parts to install; oil cooler, lightweight crank pulley, short shifter adapter/cable plate, and maybe an egt gauge. I've been daily driving it, with zero issues, ive never seen more than 5-6psi so far. I didn't play with my tune all summer, I might try fiddling with it soon. I've bought another yaris so I'm currently looking for another fic 6 or just an harness so I can get stock maf logs. |
#31 |
Looks awesome, Jeff! I have the same Prosport boost gauge. I have been driving my car almost daily and other than the long cranking in warm weather, the driving is near perfect. I think my stock ECU has adjusted out the fuel tables and I get no bucking or hesitation with any throttle position, load or rpm. Transition to boost used to be an issue, and then I would adjust the fuel table or O2 table and the hesitation would just move to a different area of the. Now it's smooth as silk. Not touching anything, making any tweaks for a period of time and it's never worked better. I get a nice rich AFR under moderate to full pedal and partial boost is in the high 12s with my w/m injection, so safe IMO. Have you tried tightening your wastegate? I was stuck at around 5 psi for a long time, until I tightened up the actuator arm. I did it twice. The first time, IIRC, I went from 5 psi to around 6.5; the second adjustment netted around 7.5 to 8 psi. Good luck with your future adjustments. I look forward to hearing about them! How do you like your aftermarket head unit? What OS is it? I doesn't look like Android.
#32 | |
Thanks! I still need to fix the floor and eventually paint it, I'll look into your welding thread for some hands-on information! Yes I've noticed that the stock ecu seems to have made some adjustments... I've noticed a slight discrepancy between the afr on the gauge and the fic software, it only goes to 13 around 4-5psi, but I think 12.5 on the fic app, will look into it more whenever I start playing with my maf map again... I have an external wastegate and I've tried different springs with no results, I suspect that my maf map is restricting the boost. The head unit sucks, the touch screen stopped functioning after maybe 8 months, at least it's still paired to my phone, Android 9.0 I think |
#33 |
Quick update as the flex pipe on the downpipe finally cracked, I replaced it and added a vband clamp, so now I can remove the downpipe without having to remove the turbo and manifold, I wish I had thought about this 6 years ago. Still running the fic 6, I tried remote tuning to no success. Will bring it to a local tuner with a dyno soon.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| my echo turbo build log | ipwnr | Forced Induction Forum | 26 | 07-14-2015 10:09 AM |
| Turbo build - stage 1:D | abstractmethod | Forced Induction Forum | 21 | 03-13-2014 08:04 AM |
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
