Floorboard lighting
Im Installing some floorboard lights this weekend and was wanting to run then to a switch beside my aux jack infront of the e-brake. Now i am uncertain where to run the wires from there. I have a cupple friends that know this kind of stuff coming over to help. I just wanted to know if anyone had any ideas because I do not know ( thats why they are coming over, together they have installed stuff like this in about 18 cars).
Any advice that anyone could give would really help! I just dont want to look like a complete idiot when we get around to it. p.s. I dont know shit about cars or working on them... |
Definitely get help but have your buddy go to Autozone or wherever and get one of these add-a-fuse thingies for mini-fuses:
![]() Here is what mine looks like with two added: ![]() I chose to put them in their own slot rather than putting two fuses into an existing slot - your choice. |
![]() ![]() ![]() Drives: 07 Yaris HB Join Date: Apr 2007
the fuse ad-a-slots allow the battery to work for the lighting?... cause i want to get some lights in the ride, but dont want to use the aux power in the dash
Rice on, Rice Off Ron Cabading |
Lighting or whatever else you want. We have a bunch of emply slots - both switched and unswitched.
sweet...and how much do these things cost? cause i want to get a set of at least 4 tubes for the interior
Cheap - about $5.
Here's a better photo: One fuse supplies power to the original circuit, the other to the red wire. Like I said, I chose to use an empty slot and just use the fuse to the wire. |
where can u buy these mini fuse thingys... aside from autozone?...
thanks for the info, should have pics up soon
Q(','Q)
ill try to ill have to go back and take pictures as soon as i get my cam fixed, very very simple can be done in about 15 -20 mintues te way i did
question...ive got a strobe bass recognizer dash neons and wanted to know and i bet its possible, if i could splice the wires and connect them to a whole next set of neons for them to intertwine strobing?
Not sure, but make sure you check the local laws. I know in Georgia all blinking lights no matter what color other then blinkers are illegal, also a lot of colors esp. blue are illegal.
Finsh the Fight
Drives: soon to be Yaris LB Join Date: May 2007
well that sucks that they dont let you put whatever color you want wit out being illegal
#14 |
You also don't want your wife/girlfriend/sister pulling over for some creep with a flashing blue or red light kit, do you?
| Interior Lighting | Typer73 | Cosmetic Modifications (Exterior/Interior) | 3 | 05-08-2007 05:34 AM |
| Guage cluster lighting | Jem_hadar | Cosmetic Modifications (Exterior/Interior) | 3 | 01-26-2007 10:32 PM |
| Interior Lighting Q | Yar | Cosmetic Modifications (Exterior/Interior) | 9 | 11-09-2006 06:55 PM |
| ambient map lighting? | atebit | Cosmetic Modifications (Exterior/Interior) | 0 | 11-05-2006 01:15 AM |
| Blue Lighting option... | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 14 | 09-03-2006 12:24 AM |
