Old 12-15-2006, 11:13 PM   #1
Yaris
Yaris's Avatar
Drives: 2010 LB Meteor Metallic
New TSB Bulletin For Windshield Washer Sprayer
Here is some info from TSB 2661 (In Canada)
Some customers may experience poor cleaning of RH side of the windshield during winter season due to insufficient washer fluid distribution. Road salt residue may be difficult to wipe due to insufficient washer fluid distribution. A field fix washer nozzle and modified cowl ventilator louver have has been implemented in the following repair procedure to prevent this condition from occurring.
APPLICABLE VEHICLES:
• 2006 - 2007 model year Yaris Hatchback vehicles produced BEFORE the Production Change Effective
VINs shown below.
PRODUCTION CHANGE INFORMATION:
+2° degree Washer Nozzle Sub-Assy Production Change Effective VIN:
Model Product Change Date Production Change Effective VIN Repair Procedure
Yaris H/B
(Both 3 & 5 Door) Feb. 27, 2006 JTDJT923275035997 1
Cowl Ventilator Panel Production Change Effective VIN:
Yaris H/B
(3 Door) Nov. 6, 2006 JTDJT923X75088754
Yaris H/B
(5 Door) Nov. 6, 2006 JTDKT923175088579
2
WARRANTY INFORMATION:
Applicable Warranty*:
This repair is covered under the Toyota Basic Warranty. This warranty is in effect for 36 months
or 60,000 kilometres, whichever occurs first, from the vehicle’s warranty registration date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
OPN Description Time OFP T1 T2
BC6038 R & R Louver Sub-Assy, Cowl Top Ventilator, RH Side 0.8 55708--52060 75 99
Yaris is offline   Reply With Quote
Old 12-16-2006, 02:22 AM   #2
RogueYaris
Drives: 2015 Abs Red
So this is only for the Canadian versions, correct?
RogueYaris is offline   Reply With Quote
Old 12-16-2006, 05:00 AM   #3
dngz
dngz's Avatar
Drives: black yaris sedan
sedan??
dngz is offline   Reply With Quote
Old 12-16-2006, 08:21 AM   #4
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
I DID experience the same. In fact, not only the passenger side washer doesn't spray enough, but both doesn't spray enough high in the windshield.
I took me 2 min. to rearrange both sprayers so now it sprays all over the windshield
hystria is offline   Reply With Quote
Old 12-16-2006, 11:36 AM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Most cars you can simply put a pin in the sparyer nozzel and hen aim it where ever you want/need it.
I've driven in some pretty crazy weather and sluch conditions and have NO issues with mine.
Then again it may have something to do with the RainX treated windshield as well.
Old 12-16-2006, 03:51 PM   #6
Yaris
Yaris's Avatar
Not sure. Your advisor would have to research it.
Old 12-16-2006, 03:53 PM   #7
Yaris
Yaris's Avatar
Originally Posted by dngz View Post
sedan??
Not yet.
Old 12-16-2006, 04:00 PM   #8
Yaris
Yaris's Avatar
The nozzle is too close to the center, so it will be moved closer to the passenger side.
Old 12-16-2006, 05:13 PM   #9
hystria
hystria's Avatar
that's right, on the pass. side it doesn't spray far enough on the right side- just have to put a pin under the nozzle to force it face more to the right. but even this solved, both nozzles don't spray high enough - to my taste
Old 05-31-2007, 10:10 AM   #10
jlift
Drives: 2007 Yaris Hatch
TSB for Windshield Wiper/Washer attached.
While I picked up my car, they service manager was kind enough to print out this TSB for me. Here you go.
jlift is offline   Reply With Quote
Old 05-31-2007, 10:20 AM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
yeah I had this problem durig the winter, but I never had time to take it in, now that it is summer I keep fogeting to take it in
Old 05-31-2007, 03:33 PM   #12
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
from what ive seen its for the united states.....
Old 05-31-2007, 08:13 PM   #13
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
thanks.
Old 05-31-2007, 10:35 PM   #14
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
i had it fixed at the dealer and it just as bad, so i when to the scrap yard and was able to find a pontiac wave the windsheild washer jet fits on the yaris but you'll have to cut the intake for the washer hose just a bit so it can hook it up. not sure if that makes sense. I'll take pics if need. the wave washer jet spray has 3 sprays. So one is adjusted at 80 degrees, 45 and 25 so the whole passenger side gets sprayed. Other toyotas will fit but they only have two sprays from what i was able to get in the scrap. and for the same amount of work might as well go with three.
Adriaan is offline   Reply With Quote
Old 06-01-2007, 01:47 PM   #15
hans_fh
Drives: Yaris
does sedan qualify for this TSB?
hans_fh is offline   Reply With Quote
