Old 06-05-2007, 06:57 PM   #1
Pavel Olavich
Drives: 2007 Yaris LB
Originally Posted by petesimac View Post
How and why were your rpms over 6,000? That's just asking for trouble. If someone's on your rear, let them pass, pull over, and just slow down. Just my opinion.
Not true....you can keep your Yaris at 6,000 RPGM all day long...the engine is nearly bullet proof, and it will take a beating plus more....that engine will not blow up at high RPM...it will last 300,000 miles of abusive use so long as it is maintained properly....no need to baby your Yaris...drive the hell out of it, if you must....it will not hurt it.
Pavel Olavich is offline
Old 06-06-2007, 09:47 PM   #2
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
lol just dont panic shift while racing and downshift from 4th to 1st at 6k... ive seen it done many times besides that i say go crazy
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline
Old 06-06-2007, 09:59 PM   #3
barryware
Or.... Rev to 6K and then slide your foot counterclockwise off the clutch.
If you have an A/T like me.... 6K while in neutral, and when you think the traffic light will turn green, drop that bitch in drive and hold on..
barryware is offline
Old 06-07-2007, 07:15 PM   #4
drifto
drifto's Avatar
yay! neutral bomb... my favorite
07 Yaris LB 5spd
drifto is offline
Old 06-12-2007, 12:19 AM   #5
captainzerocool
CAMRY FTW!
captainzerocool's Avatar
Drives: Camry LE V-6 (225,000+ miles)
If your not joking.... Then you are as dumb as paris hilton.
I drive a Camry.
I have no imagination.
captainzerocool is offline
Old 08-20-2007, 01:26 PM   #6
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
YarisTom73 is offline
Old 06-12-2007, 03:48 AM   #7
If you have an A/T like me.... 6K while in neutral, and when you think the traffic light will turn green, drop that bitch in drive and hold on as your car jumps over the remnants of its transmission that just dropped on the floor
sounds about right
eTiMaGo is offline
Old 08-20-2007, 06:52 PM   #8
Pavel Olavich
Only an idiot would do this....
Old 08-20-2007, 06:51 PM   #9
Pavel Olavich
I doubt you've seen it many times....who and why would anyone downshift from 4th to 1st gear? I doubt the manual tranny would let you do it even if you wanted to....
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 09:13 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 08:17 PM
service engine light @ 9000 mi? dandj DIY / Maintenance / Service 21 01-03-2007 01:30 AM
High compression engine flow-vitz General Yaris / Vitz Discussion 1 11-15-2006 02:03 PM
Check out my new light ( SEDAN )) mariosuper Cosmetic Modifications (Exterior/Interior) 5 09-22-2006 10:06 AM
