Old 07-04-2007, 10:09 AM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
Since you can't see it from the side, I think I'm gonna switch the two, so the turn signal is in white...
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 07-07-2007, 08:06 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
ummm.... what?
Old 07-07-2007, 08:52 AM   #3
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
freaking nice DIY by the way
it's legal in canada to have white running light on mirror some FJ cruser have some little round white light on the mirror!
the_boss is offline   Reply With Quote
Old 07-07-2007, 03:47 PM   #4
Violin
Violin's Avatar
There is a bundle of 4 wires running up from inside the fender to up under each headlight. Those are the ones I have pictured. You have to remove the headlights to get at them. Tap the wires I showed for power - the red wire from the mirror is the power wire for the amber LED and the black is the ground. The ground can go to just about any bolt inside the cabin.
Thanks for translating.
Old 07-07-2007, 07:15 PM   #5
the_boss
the_boss's Avatar
Ok here we go!
Ya une couette de 4 fils qui passe dans chaque coter de fender (aile) jusqua la lumiere avant. ses ceux qu'il a photographier. Faut enlever l'assemblage de la lumiere pour y acceder. tap le fil qui apporte le courant au blinker avec le fil rouge du miroire (courant pour les led jaune) et le noir ses le ground ou mise a la terre, tu peut grounder sur n'importe quel boulons pis sa va faire!
NOTE DE MOI MEME: prend le fil conducteur des blinker avant pis plug les avec le rouges des led jaune du mirroires. dans sa photo y montre quel fil tu doit connecter!. Jespere que sa va aider!
Old 07-07-2007, 08:17 PM   #6
love the global community around here!!!
I am definitely doing this mod. Anyone know where I can get CF LED mirrors?
Old 07-07-2007, 08:28 PM   #7
one more thing. If you don't mind my asking, why not just wire to the side marker, which is only about a foot away from the mirror?
Old 07-21-2007, 10:46 AM   #8
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Because he's anal.
Old 07-08-2007, 08:08 AM   #9
Violin
Violin's Avatar
You could do that, I even had mine popped out for that purpose but decided it was neater where I tapped it.
Old 07-20-2007, 08:36 PM   #10
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
im gonna get rid of my side markers with this mod, lol, is way better
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 08-02-2007, 05:34 PM   #11
Canuck
Drives: 07 5 door Hatchback
You do realize that the side markers let the idiot in your blind spot know that you and to turn andthat mirror won't achieve that right?
The side markers are a safety thing.
Canuck is offline   Reply With Quote
Old 08-02-2007, 09:40 PM   #12
Yes but strangely enough, go look around at pics of the stock USDM sedan... no side markers!
Old 08-02-2007, 11:12 PM   #13
Canuck
And a lot of US cars still have red rear turn signals that are impossible to see, What's your point?
Old 08-03-2007, 06:35 AM   #14
Violin
Violin's Avatar
But you can see the front turn signals on the sedan from the side:
Not so with the liftback.
Old 07-20-2007, 09:30 PM   #15
Violin
Violin's Avatar
You'll patch and paint the holes in the fender?
Old 07-31-2007, 05:19 AM   #16
looks good man, is the "white" light really that blue in person or is your camera playing tricks?
Old 07-31-2007, 05:49 AM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great install! Looks awesome bigsky2!
Did you add a switch in order to change between LEDs easily? If so, could you please let me know which model you used? Thanks!
Old 07-31-2007, 06:13 AM   #18
hahah yeah, now if only I could actually finish wiring them up myself someday
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
