Old 07-03-2012, 06:06 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive been running a ram air duct into my air box with the opening in the foglight hole. Ive ran 3 tanks this way with no noticeable difference in mpg. Highway power maybe feels better?
Im thinking ill make my own proper CAI using the blox...i really like that and i think i can squeeze it in the bumper...i got hammers...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-03-2012, 06:38 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I got hammers...
I was checking around on ebay and it appears that BLOX also makes a much smaller 4 inch diameter velocity stack filter...
You can tell the smaller filter diameter because it has almost no taper as compared to the 7.5 inch filter, but yet has the same black plastic end cap. The only unknown is the inlet diameter, but that could be determined simply by asking the seller. One negative... it's pricey at $77 including shipping.
edit: from checking around, that may actually be a 4 inch inlet filter and not useable on the Yaris. The seller could confirm whether the filter itself is 4 inch diameter, or the inlet is 4 inch diameter.
Old 07-03-2012, 08:25 PM   #3
malibuguy
Obsessed with 1.5L
Well worse case scenario ill use an aem dry filter. I used a 2.5" vibrant filter when i fab'd the intake on my old xB...but it had a nasty internal lip to reduce it to 2.5" from 3"...friggen joke. I gave that filter away when i traded that in for the Yaris
-96 Tercel 4dr
Old 07-03-2012, 09:22 PM   #4
tooter
play every day
tooter's Avatar
I just emailed the ebay seller to find out for sure as I'm really curious about that.
Old 07-03-2012, 10:45 PM   #5
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Ok went from intake manifold project to talking about headers and velocity stacks...
Old 07-04-2012, 12:11 AM   #6
tooter
play every day
tooter's Avatar
I'll be sure to let you know everything that happens on the manifold project. I'm getting a baseline dyno on Thrusday and will post the results here.
Old 07-04-2012, 01:32 AM   #7
tooter
play every day
tooter's Avatar
Just read the old 2008 thread on Richard Holdener's intake manifold...
Over the last 4 years it appears like there has been a constant string of obstacles and setbacks which have prevented anyone from being able to produce a better intake manifold than the one which is already on the engine.
In the light of what I've just been reading, makes it extremely unlikely that my Yaris is going to run any better with a jiggered 14 year old Corolla manifold on it, even though I'm already into the project for about $1,400 and just getting started!
Nevertheless, I'm going to find out, not to arrive at some goal, but just for the personal enjoyment of following my own uneducated interest in flow design. I like to follow my own intuition just to see where it leads me, and I'm happy to share the details of every event as it unfolds with all of you.
Old 07-04-2012, 08:02 AM   #8
Viperoni
Drives: 2005 Toyota Echo
2006 Saturn Ion Redline
Old 07-04-2012, 09:49 AM   #9
malibuguy
Obsessed with 1.5L
That 2-piece WR header is for a k-series honda.
-96 Tercel 4dr
Old 07-04-2012, 10:45 AM   #10
^ Correct. They never made it for the Yaris. IF there is one on eBay that is for the Yaris, it's made by someone else.
Old 07-04-2012, 11:00 AM   #11
tooter
play every day
tooter's Avatar
Yeah, I just took another look at that ebay auction. Scrolling down to the bottom, there's a disclaimer on the photo. They're just selling the short header #953-116-108.
So that leaves this Kansai 4-2-1 as being the only long runner header...
The ad says: "Call for Price".
100,000,000,000 yen.
Old 07-04-2012, 11:36 AM   #12
Trust me guys, if there were a long header available from an existing vendor, it would be in my store.
Old 07-04-2012, 09:54 PM   #13
malibuguy
Obsessed with 1.5L
Ill be making one for mine too one day...its going to be a trick
-96 Tercel 4dr
Old 07-05-2012, 02:21 AM   #14
tooter
play every day
tooter's Avatar
Do you think it'll be a challenge to get the 02 sensor bung in the right place so as not to trigger the check engine light? If you could see there they put it on the Kansai, that might be a big help unless there aren't any on it to begin with.
Old 07-05-2012, 10:24 AM   #15
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
The real challenge is that the o2 sensor is far enough away to get an accurate reading but not to far away that the results are delayed.
The CEL isn't really an issue with the front o2 as that is getting readings its the rear o2 that triggers the cat efficiency light.
Old 07-05-2012, 10:25 AM   #16
^ You don't have much choice - it need to be as soon after the final collector as possible. Hit and miss on whether it throws CEL's or not, it's not possible to predict with any certainty.
Old 07-05-2012, 01:38 PM   #17
malibuguy
Obsessed with 1.5L
Usually just spacing the 2nd O2 sensor out of the exhaust stream just enough fools the ecu good enough...mine is currently spaced out now since toyota doesnt like anything other then a stock cat. And im running a 100cell race cat
-96 Tercel 4dr
Old 07-05-2012, 05:44 PM   #18
tooter
play every day
tooter's Avatar
Just got back from the dyno shop...
The results of the 3 runs was:
98.87HP
99.18FT/LB
99.90HP
101.00FT/LB
99.93HP
01.22FT/LB
Mods:
Weapon R Short Ram Intake with BLOX Velocity Stack Air Filter
Weapon R 4-2-1 Header
Micro Image MagnaFlow Center Exit Exhaust
So the engine essentially made 100HP with those mods.
Here's the chart:
Does anyone have a dyno run of a completely stock Yaris for comparison?
I'm uploading the video to You Tube right now and will post the link as soon as it's done.
The dyno runs were done at this shop:
HK Motorsports
15020 Oxnard Street Unit A
Van Nuys, CA 91411
818-908-9650
http://www.hkmotorsportsdynoshop.com/
Harry, the owner is a good guy.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
