Old 12-01-2012, 03:35 AM   #163
odg495
odg495's Avatar
Drives: Yaris & Corolla
Originally Posted by tooter View Post
Nice...
Looks like a BMW M5 exhaust.
I was thinking more M3, but hey, I'm not going to argue!
odg495 is offline   Reply With Quote
Old 12-03-2012, 08:40 PM   #164
larryn2o
larryn2o's Avatar
Drives: 08 yaris
cherry bomb
this one is a 2 inch pipe with a 2 inchcherry bomb turbo muffler, passes for a stock muffler. low tone unloaded . a good bit louder under load.
cost $24 at autozone and $44.00 to get the pipe bent and welded.
I know it's not stainless or Unobtainium , but I've already started my next axle back , will post it in a few days.
http://www.youtube.com/watch?v=fPtaWvaIkU0&list=UL
larryn2o is offline   Reply With Quote
Old 02-27-2013, 08:58 AM   #165
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Anyone using the Apexi Bomber exhaust??
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 03-22-2013, 07:58 PM   #166
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
DC Sports axle back
Also have K&N Typhoon intake and DC Sports header
yariSB86 is offline   Reply With Quote
Old 03-22-2013, 08:01 PM   #167
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Sounds like beautiful music...
Old 03-22-2013, 08:03 PM   #168
yariSB86
yariSB86's Avatar
Thanks man.
I'm waiting on a couple prospects for my mid pipe replacement. should sound even most beastly when its all done.
Old 05-31-2013, 01:15 PM   #169
Turbotoro
Drives: 05 Vitz
Hey guys, figured I'd post here because I'm having a super hard time finding an axle back for my 05 echo (in Canada) anyone want to point in the right direction or sell me their exhaust? Lol thanks any info would be appreciated
Turbotoro is offline   Reply With Quote
Old 09-01-2013, 03:49 PM   #170
mrtobs1988
Drives: 2009 toyota yaris white
Originally Posted by mrbond View Post
Well, personally I think it's worth the money. You can't have an efficient engine if your intake and/or exhaust is too restrictive (which is what the Yaris was cursed with out of the factory). If you wanted to replace your exhaust, I'd start with the axle-back so that you can find which kind of sound you like. Then you have the option of either going with the Nitto midpipe (available from microimageonline.com) or custom-fabricating your own midpipe (warning: the Nitto midpipe does not have any catalytic converters; they're just resonators). And you know, I would recommend replacing the header. The stock design is rather convoluted and doesn't lend itself well to a good exhaust flow. For this you have many options: TRD (expensive as all hell), Megan, DC, Thunder, DME, or, again, custom make your own. If you plan on doing more performance modifications to your car, a good exhaust system is pretty much invaluable. Hope that answered your question well enough :D
Hey is that the only midpipe you can find. And why is it so expensive? Is there anything cheaper that you know of?
mrtobs1988 is offline   Reply With Quote
Old 09-08-2013, 09:52 PM   #171
brutal910
brutal910's Avatar
Drives: 2007 tyota yaris 2 door hatchb
inspection fail, texas
Hey fellas, I could use some help here.I have a 2007 yaris hatchback. 1.5 liter 5 speed. DC header, greedy full exhaust , no cat. And some little gadget box with wire that is suppose to trick ecu that it does have a cat engine light on. Code his for 0/2 sensor upstream. If I install a new 0/2 sensor my engine light should turn off right? I only have 15 days to fix this problem. And I'm on my eighth day.otherwise I will have to pay for another inspection. Please help. I didn't see another 0/2 sensor under there unless I missed it. Mechanic suggested I change both. 318.00 bucks for parts. :-(
brutal910 is offline   Reply With Quote
Old 04-30-2014, 02:07 AM   #172
Vitz_Q8
Vitz_Q8's Avatar
Drives: 3dr NCP90R
This is my very first post and hopefully not the last. I've been visiting yarisworld for a while occasionally until I finally bought my Yaris couple of months ago. I've been always a big V8 sedan guy but when I rented a Yaris in a road trip last I fell in love with it instantly, I don't know how to explain my feeling but wow, Huge difference from my Crown Vic and Aus Ford Falcon.
Anyway let's get to the topic . After a very long wait I finally got Tanabe Concept G Exhaust for my Yaris. Thanks to redyaris's post I managed to install it by myself. It was a relatively easy task but took me about 6 hours because the right wheel and one of the mufflers's spring bolts were stuck even with WD-40 and some hammering.
here are the pictures:
I really love it. At first I thought it's a little bit loud and annoying especially on long drives. there was a moment when I regretted installing it and thought about reinstalling the OEM exhaust but now I Think I got used to it by now and I absolutely love it. I will upload a video as soon as it's uploaded on Youtube
http://youtu.be/6OUqDz-pF2c
Vitz_Q8 is offline   Reply With Quote
Old 05-10-2014, 12:05 PM   #173
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Current setup
Custom long tube header
2.5" exhaust w/ cut-out
I Drive a 129whp Yaris ;)
Old 05-21-2014, 05:13 PM   #174
j-san
Drives: 2010 5-door hatchback
A question for you exhaust gurus:
A search of the forum turns up conflicting reports of a freer-flowing aftermarket exhaust system improving/hurting MPG. Some said it improves MPG and power, others have said it hurts MPG, but improves power. Either way, it seems a better exhaust will improve power and possibly affect MPG.
I drive with a fairly light foot and mostly on the highway and average 43MPG most days. My Yaris is stock, but I am open to doing an aftermarket exhaust, provided it doesn't sound like bad rice and seriously hurt MPG. I wouldn't mind the few extra HP for a little help in the passing lane. If I go aftermarket, I plan to leave the intake stock and drop in a K&N filter. Maybe a header is fine, but I plan to leave the cats and resonator intact and possibly add an additional resonator after the stock one. There is a local custom exhaust shop that can do the work and I would ask them to follow the stock piping, but go up to a 2" pipe vs the stock 1.75" pipe (I understand the cats and resonator use a 2" pipe) and route it to the factory flange at the rear axle. From there, I'll probably bolt on a Tanabe Medalion or Nitto (plan to buy from Micro Image) as those two seem to be the quietest mufflers. How does that sound for an exhaust set-up?
I am not expecting oh-my-god gains in HP or anything, but hope to have a little of both worlds: improved HP while being able to retain (or improve) MPG.
j-san is offline   Reply With Quote
Old 05-22-2014, 03:07 PM   #175
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
Originally Posted by YarisPR View Post
Current setup
que porqueria Angelo jajajajajajaja
monchito18 is offline   Reply With Quote
Old 05-22-2014, 09:35 PM   #176
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
To be honest. Keep the stock exhaust for mpg. I usually have run about 3mpg less with my exhausts. Most of the fact that I love to listen to my exhaust. Plus the stock exhaust is better matched for low rpm performance.
A typical muffler shop will only crush-bend tubing. So their 2" tubing is typically smaller in the bends then your stock midpipe. So the only thing your getting is no improvement in exhaust flow and lower quality tubing that will rust out eventually.
I suggest a rear section exhaust for some power and sound and not throwing away all your mpg.
These motors really love a full exhaust so real gains in power can be realized
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-23-2014, 09:04 AM   #177
j-san
Thanks much for the advice. I may just look into getting a axle-back system like the Tanabe Medalion and leave the rest stock. Maybe have the shop weld in another resonator if I find the aftermarket muffler too noisy.
Old 07-09-2014, 02:03 AM   #178
dekraberd
Drives: 2013 3Dr Super white
File Type: jpg 10149401_4180781214496_247067220_n.jpg (140.9 KB, 443 views)
dekraberd is offline   Reply With Quote
Old 07-13-2014, 09:40 PM   #179
salmanghiyas
Fugitive
Drives: 2007 Yaris 4 Door Hatch
what is the basic function of these cats ?
please suggest what option from below should i go, for the maximum HP gains .. regardless of fuel economy ..
1: remove both cats and resonator and put a straight down pipe of 2" or 2.25" ( please suggest which is better 2" or 2.25" ) till the end ...
2: keep the 1st cat and remove the second cat and the resonator and put a straight down pipe till the end ...
3: keep both cats and just remove the resonator and put a straight down pipe till the end ...
4: keep both cats and resonator just put a straight down pipe after the resonator till the end ...
5: remove both cats just keep the resonator and put a straight down pipe till the end ...
salmanghiyas is offline   Reply With Quote
Old 07-13-2014, 09:44 PM   #180
mario98c
mario98c's Avatar
Remove both cats with 2" exhaust and magnaflow freeflow muffler
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Why is DTM exhaust thread closed? gr8yaris Performance Modifications 4 01-13-2007 11:01 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
