#1 | |
I believe that's about 10whp above stock... Not too shabby.
http://www.yarisworld.com/forums/showthread.php?t=10320
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() I think my excel sheet matches up pretty well. DATA!!!!!!!!! |
#3 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
But what does it mean?
#4 |
"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Good results! I'm sure someone will chime in with stock dyno run, but unlikely we have one from a 2012 like yours. Your car has a different ECU than the 07-11 cars so it may net different results, certainly seems to like the few bolt-ons you've got so far!
www.microimageonline.com |
#5 |
play every day
Here's a video of the 4th gear run...
http://www.youtube.com/watch?v=rYF6pvhn96U Hey Jeff... ![]() Your MI exhaust sounds really cool! Last edited by tooter; 07-05-2012 at 10:51 PM. |
#6 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Damn...our cars really like exhaust then...i have less intake and more exhaust and have 7-8more whp.
I wonder how much a long header could really produce
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#7 |
play every day
For comparison, what intake and exhaust are you running? The bottleneck on mine is the stock mid tube.
#8 |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
If you plan to stay NA, start with the header...the stock "collector"(not sure if correct term) where the 4 pipes of the header joins together is very very small and that restricts quite abit of power
#9 |
play every day
#10 |
Obsessed with 1.5L
Stock air box...removed carbon filter and im running an Apex-i drop in replacement filter. I made a full custom 2" mandrelbent exhaust. I also have amsoil synthetic trans and engine oil. Also i have a weaponr header too
#11 |
play every day
Ah, there's where you got those extra horses.
![]() Since I have a header and an axleback, that bigest gain is found in the midpipe. |
#12 |
those numbers are interesting. I was hoping for around 105 or so. I am actually going to be going 2" from the resonator back with mine. there is a short section that is actually oval shaped that seems really restrictive.
I am really looking forward to seeing what your intake manifold does for you. any ETA on when that is going to be finished? |
#13 |
play every day
I was hoping for 95 horsepower.
![]() After, all I've only done just a few simple peripheral mods. The CNC guys were concurrently working on multiple machining deadlines so mine had been getting pushed back. The other projects are finished now so they're working on mine. Just talked with them this morning and they're modelling the face plate design to accept the stock intake manifold gasket. I want this to be something that everything fits properly so I can simply bolt it on and run it. ![]() I showed the manifold to Harry, the guy who runs the dyno shop, and he told me that while the manifold should show some power gains above 4,000 it will be at the sacrifice of power down in the 2,000 to 3,000 rpm range. He said it was because the larger volume of the runners will slow down the velocity of the air at low rpms. The question is how much bottom end will be lost... I'll find that out on the next dynos.
#14 |
it would be nice if you had a data file of the dyno and you could literally see the delta (positive or negative) in maybe 100 rpm steps. I know that it may be too late for that. maybe you could overlay the two dyno runs if your dyno guy keeps the files (I assume he would)
I like the progress you are making. it may be advantageous for you to go to a muffler shop and get them to replace that run of 1.75" pipe with 2"...obviously not until you get the intake manifold experiment done. when you get the manifold done, we definitely need some pics of the final product also. |
#15 | ||
play every day
![]() Dynojet Research Inc. Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_001.drf Run Title: 2012 Toyota Yaris Greg Mamishian Run Notes: Weapon R Intake BLOX Velocity Stack Air Filter Weapon R 4-2-1 Header Micro Image MagnaFlow Exhaust Run Date: 7/5/2012 12:07:06 PM RunFile_001.drf: 78.46 °F 29.19 in-Hg Humidity: 45 % SAE: 1.02 Average Gear Ratio: 52.53 s RPM x1000 hp ft-lbs Air/Fuel 0.69 2.10 34.69 86.77 14.89 1.47 2.20 37.21 88.84 13.05 2.25 2.30 38.89 88.80 12.36 3.00 2.40 41.30 90.38 12.36 3.76 2.50 43.35 91.07 12.42 4.51 2.60 44.87 90.65 12.30 5.28 2.70 45.91 89.31 12.15 6.05 2.80 47.64 89.36 11.98 6.82 2.90 49.39 89.45 11.70 7.60 3.00 50.66 88.69 11.90 8.38 3.10 52.12 88.31 11.79 9.15 3.20 54.52 89.49 11.93 9.90 3.30 57.61 91.69 12.35 10.65 3.40 60.03 92.73 12.35 11.39 3.50 62.20 93.34 12.18 12.12 3.60 65.50 95.56 11.98 12.84 3.70 66.59 94.53 11.95 13.57 3.80 68.98 95.34 12.08 14.29 3.90 72.28 97.33 12.39 14.99 4.00 74.58 97.92 12.29 15.70 4.10 76.66 98.20 12.08 16.41 4.20 77.84 97.33 12.11 17.11 4.30 79.09 96.60 12.11 17.85 4.40 81.29 97.03 12.16 18.57 4.50 82.25 96.00 12.30 19.30 4.60 84.32 96.27 12.21 20.01 4.70 86.01 96.12 12.29 20.76 4.80 87.75 96.02 12.41 21.49 4.90 89.12 95.53 12.40 22.23 5.00 91.66 96.28 12.49 22.96 5.10 93.48 96.27 12.66 23.70 5.20 95.13 96.08 12.91 24.43 5.30 95.75 94.88 13.22 25.18 5.40 97.30 94.64 13.54 25.97 5.50 98.27 93.84 13.82 26.72 5.60 98.02 91.93 14.01 27.51 5.70 98.19 90.47 14.23 28.33 5.80 97.09 87.92 14.36 N/A 5.90 N/A N/A N/A 29.99 6.00 97.60 85.47 14.62 --------- --------- --------- --------- --------- MAX: 29.99 6.00 98.27 98.20 14.89 MIN: 0.69 2.10 34.69 85.47 11.70 -------------------------------------------------------------------------------- Dynojet Research Inc. Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_002.drf Run Title: 2012 Toyota Yaris Greg Mamishian Run Notes: Weapon R Intake BLOX Velocity Stack Air Filter Weapon R 4-2-1 Header Micro Image MagnaFlow Exhaust Run Date: 7/5/2012 12:17:31 PM RunFile_002.drf: 79.85 °F 29.19 in-Hg Humidity: 43 % SAE: 1.02 Average Gear Ratio: 52.49 s RPM x1000 hp ft-lbs Air/Fuel 0.69 1.80 26.43 77.12 14.89 1.57 1.90 28.78 79.55 10.00 2.38 2.00 32.66 85.78 10.31 3.17 2.10 35.21 88.07 11.72 3.93 2.20 37.94 90.58 11.88 4.69 2.30 39.27 89.68 11.91 5.44 2.40 41.93 91.76 12.00 6.19 2.50 44.02 92.48 12.04 6.93 2.60 45.80 92.53 11.71 7.68 2.70 47.11 91.64 11.69 8.43 2.80 48.68 91.31 11.82 9.18 2.90 50.37 91.23 11.74 9.95 3.00 51.69 90.49 11.79 10.71 3.10 53.59 90.80 11.82 11.46 3.20 55.84 91.65 11.91 12.20 3.30 58.45 93.02 12.33 12.98 3.40 60.89 94.05 12.33 13.40 3.50 62.50 94.13 12.17 14.38 3.60 66.31 96.74 11.95 15.10 3.70 68.15 96.74 12.06 15.88 3.80 70.26 97.11 12.16 16.51 3.90 73.62 99.15 12.24 17.20 4.00 76.60 100.57 12.35 17.90 4.10 77.95 99.86 12.21 18.60 4.20 78.93 98.70 12.12 19.29 4.30 80.56 98.39 12.16 20.02 4.40 82.43 98.39 12.24 20.71 4.50 83.86 97.87 12.29 21.44 4.60 86.06 98.26 12.20 22.16 4.70 87.22 97.46 12.22 22.88 4.80 89.28 97.69 12.30 23.60 4.90 90.73 97.25 12.35 24.33 5.00 93.11 97.80 12.31 25.06 5.10 94.49 97.31 12.25 25.78 5.20 96.40 97.37 12.33 26.51 5.30 97.90 97.02 12.40 27.25 5.40 99.20 96.48 12.61 28.00 5.50 99.22 94.75 12.92 28.77 5.60 99.45 93.27 13.29 29.57 5.70 98.75 90.99 13.62 30.37 5.80 99.30 89.92 13.89 31.19 5.90 98.67 87.83 14.11 32.05 6.00 97.61 85.44 14.29 --------- --------- --------- --------- --------- MAX: 32.05 6.00 99.45 100.57 14.89 MIN: 0.69 1.80 26.43 77.12 10.00 -------------------------------------------------------------------------------- Dynojet Research Inc. Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_003.drf Run Title: 2012 Toyota Yaris Greg Mamishian Run Notes: Weapon R Intake BLOX Velocity Stack Air Filter Weapon R 4-2-1 Header Micro Image MagnaFlow Exhaust Run Date: 7/5/2012 12:22:20 PM RunFile_003.drf: 80.12 °F 29.20 in-Hg Humidity: 41 % SAE: 1.02 Average Gear Ratio: 52.46 s RPM x1000 hp ft-lbs Air/Fuel 0.75 2.50 44.23 92.92 12.69 1.49 2.60 45.99 92.90 12.16 2.24 2.70 47.27 91.96 12.03 2.99 2.80 48.95 91.82 12.04 3.75 2.90 50.38 91.24 12.06 4.50 3.00 51.93 90.91 12.04 5.27 3.10 53.56 90.74 11.95 6.02 3.20 55.65 91.34 12.08 6.77 3.30 58.54 93.17 12.54 7.50 3.40 61.18 94.50 12.52 8.22 3.50 63.54 95.35 12.25 8.94 3.60 66.56 97.11 12.02 9.65 3.70 68.05 96.60 12.07 10.37 3.80 70.09 96.87 12.37 11.07 3.90 73.58 99.09 12.48 11.76 4.00 76.68 100.68 12.56 12.45 4.10 78.78 100.92 12.32 13.15 4.20 79.58 99.52 12.33 13.83 4.30 81.10 99.05 12.32 14.56 4.40 83.05 99.13 12.35 15.27 4.50 84.57 98.71 12.26 15.98 4.60 86.14 98.35 12.18 16.69 4.70 87.84 98.16 12.29 17.41 4.80 89.39 97.81 12.31 18.14 4.90 90.94 97.47 12.22 18.86 5.00 92.20 96.85 12.13 19.59 5.10 94.17 96.97 12.15 20.32 5.20 96.37 97.34 12.17 21.05 5.30 97.80 96.92 11.96 21.79 5.40 98.64 95.94 11.96 22.55 5.50 99.23 94.76 11.93 23.32 5.60 99.72 93.53 11.97 24.11 5.70 98.34 90.61 11.89 24.92 5.80 98.45 89.15 11.78 25.75 5.90 98.30 87.51 11.76 26.60 6.00 98.02 85.80 11.94 --------- --------- --------- --------- --------- MAX: 26.60 6.00 99.72 100.92 12.69 MIN: 0.75 2.50 44.23 85.80 11.76 Quote:
![]() With the short ram completed and the baseline dyno done, everything is now waiting on the CNC guys to punch out the head flange and throttle body adapter. Then I go the welder to get the flange put on. Then I get the whole thing sandblasted.
#16 | ||
Dyno's vary and can really only be relied on comparisons to personal runs....or if a stock yaris runs on the same day. That said, 100whp with the wimpy stock 1.75" midpipe makes sense...
#17 |
play every day
I understand... and that's why I'm not concerned with the absolute output of any one dyno run as far as the exhaust is concerned. Right now I'm focused on the intake manifold and in the relative difference between two dyno runs with the manifold as the only difference.
Maybe later on I'll post another thread on "tooter's exhaust adventure". But not now. Just one project at a time.
#18 |
that's beautiful. excel can be your friend. that will show you the advantages and disadvantages to your intake manifold.
you have quite the project going here. now I am chompin at the bit for more. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
