Old 10-04-2010, 02:53 PM   #1
madz
Drives: Vitz 2008
Hello Guys,
i need to change stock tires size 165/70/14 BS of my Japanese vitz with 185/60/15
I already got japan vitz OEM 15 rims...
Can anyone tell me..which is ideal replacement size for 15" based on my stock tires 165/70/14..
will it cause any problems with suspension shocks, speedo ratings etc?
thanks!
madz is offline   Reply With Quote
Old 11-13-2010, 11:33 AM   #2
husaynkhan
Drives: new vitz
Hi everybody, i wanted to have the opinion of each oF u. I wanted to know which best tire can fit my car properly. i've just install New Rims 14'' and am having a 175/70R14.
i want the to have a bit thin, not that much but a bit..........will 185/60 go.?
husaynkhan is offline   Reply With Quote
Old 11-13-2010, 01:53 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Not sure what you mean by a "bit thin" but these sizes generally work very well:
Tyre Size = Diameter (inches)
175/65/14 = 23.0
185/65/14 = 23.5
195/65/14 = 24.0
195/60/14 = 23.2
205/60/14 = 23.7
215/60/14 = 24.2
Old 11-14-2010, 05:43 AM   #4
husaynkhan
Drives: new vitz
But what are these numbers
23.0
23.5
24.0.....etc???
Old 11-17-2010, 08:38 PM   #5
Klink10
Klink10's Avatar
23.0
23.5
24.0.....etc???
Those are the diameter figures for the wheel and tire package they are next to.
ie: 185/65/14 = 23.5 would mean a 185/65 tire mounted on a 14" rim would be pretty darn close to 23.5 inches in total diameter.
Old 11-17-2010, 06:05 PM   #6
nimdeos
Drives: 2007 yaris sedan
Hi guys ... lots of info here. I need to know if the following snow tires will fit my 2007 sedan a la yarismo.
195/65/15
Its not on the list in above posts ...but thought I should double check.
Thanks !
n
nimdeos is offline   Reply With Quote
Old 11-17-2010, 07:21 PM   #7
kimona
kimona's Avatar
195/65/15
Thanks !
n
They're pretty darn tall... but they will fit.
Old 11-18-2010, 06:34 AM   #8
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Size.............Offset Range.....Backspace Range.......Weight
14" x 6"........6 to 32mm........93.2 to 119.2mm .......13.6lbs
Based on that data, what would be the most preferred configuration for my wheels?
Midnight Drifter is offline   Reply With Quote
Old 11-20-2010, 10:06 AM   #9
kimona
kimona's Avatar
Depends on the size tyre you want to run, if you are dropped, and whether you want to make camber adjustments.
If you simply want to bolt some wheels on your car, then 14x6, ET32 would work with 175-185mm tyres.
Old 11-23-2010, 07:28 AM   #10
Midnight Drifter
Going Retro
Kinda trying to go wide here... if 205 can fit then 205 would be my preference. If not wider (somehow) Not looking to change camber, while grip is important daily drivability-even tire wear is twice so. Can I push 215? The more rubber, the better.
I think the wheels I'm looking at are lighter than stock steelies, but couldn't tell you for sure lol.
Old 11-23-2010, 12:30 PM   #11
kimona
kimona's Avatar
14x6, ET40-45, 205/60/14
Old 11-23-2010, 07:06 PM   #12
Midnight Drifter
Going Retro
Stupid question here, what's ET? ._.
Old 11-23-2010, 03:18 PM   #13
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i know some people are pushing 225mm tires on a 6" rim... but the side wall looks like its at a 45 degree angle off the rim.. also thats stock suspension.. my race rims are 15x7 with a 40ET. i run 225/50/15 khumo v700.. if i turn the steering wheel all the way left or right, the tires rub on the chassis
Old 11-23-2010, 08:34 PM   #14
kimona
kimona's Avatar
Offset.
Old 11-27-2010, 01:35 AM   #15
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
What about a 15x7 +27 offset with a 195/55/15 tire.I'm already lowered about 1.7". Is it possible? How much negative camber and fender pulling and rolling are we talking about?
marlondog is offline   Reply With Quote
Old 12-20-2010, 08:58 PM   #16
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
This is what I'm aiming for
I Drive a 129whp Yaris ;)
Old 02-13-2011, 02:13 PM   #17
henry33
Drives: yaris1.33
is it ok to put 6.5J R15 ET (offset 35) on the yaris hatchback ? I do not know if the offset is good since originally there was Et40
thank you
henry33 is offline   Reply With Quote
Old 02-13-2011, 04:11 PM   #18
kimona
kimona's Avatar
^^ Which size tyres will you run?
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
