#1 |
Gas Guzzler
I have the hi beam kit and it fits perfectly. You just have to turn the rubber piece behind the bulb inside out to fit the larger bulb casing.
As far as installation goes... It's just as easy as changing the light bulbs only you have the added step of mounting the ballasts. |
What does everyone think of these kits on EBay??
http://cgi.ebay.com/ebaymotors/HID-B...spagenameZWDVW http://cgi.ebay.com/ebaymotors/XENON...spagenameZWDVW I know low price soooo........Has anyone had problems with the Bi beam fitting. I Imagine they would all be of correct size and not oversized. |
#3 | |
I know right?
I tested a bi-xenon kit from Xenonlink.com and it did not fit in my LB's headlight setup. The springs that hold the bulb in would not work with the HID bulb. I'm sending the kit back for a refund. I have ordered another kit from xenithxenons.com, who have tested their bi-xenon kit on Scion xBs, which also use H4 and have a similar spring retaining system so hopefully this kit should be compatible with our cars. I'll let you guys know what the results are.
-Kev 07 Bayou Blue Liftback 5-spd manual |
#4 |
Did anyone ever figure out how to adjust the headlight??? Or do you just tuen that 8mm nut?
#5 |
Pop your hood.. look for a black round barrel on the inside (engine side) of the light housings, with a white + in the center.. thats your adjuster.
#6 |
Right on. I posted the comment when i was at work and in a hurry. I just checked the manual online and seen it, but for some reason I couldnt find it before. I guess I will try to lower the headlights before I give up on the HID's until someone starts selling retrofitted headlight assemblys so I dont have to mess with it. Also Chris I was curious how you have the stock assemblys and no one has flashed you. Is it in the bulb for some people like with the glare shields or de people re aim??? I just have no idea how people have HID's without retrofitting or lowering the assemblys.
#7 |
This here:
#8 |
Sedan is different. Just went outside andfound it. It looks like a light grey wheel with a 8mm nut in the middle. I just turned it clockwise and lowered my lights. Looks a 100 times better.
#9 |
![]() Drives: Toyota Yaris RS Join Date: Feb 2009
I am now returning the 8000K hid lights back to the store. After installing the lights I found out that I cannot have these lights working on my car with the DRL module. In Canada its the law to have DRL ( Daytime running lights). It would be a $360 ticket without it. So I contacted the supplier and he told me to return it. Thats $300 bucks back in my wallet!
#10 |
![]() Drives: Yaris RS Hatchback Join Date: May 2009
anyone know what to do with the yellow wires for the halogen on the top, where to connect them too?
#11 |
When you unplugged your halogen bulb, the connector should have 3 wires in it.. is this what you are talking about?
#12 |
i bought the High/low H4 kit, came with a halogen bulb for the high beam. it came with two yellow wires for the halogen light bulbs. i dont know where to wire them too
#13 | |
Send me a link for your kit or a copy of the wiring diagram and I'll solve your problem. I also have a 2007. |
#14 | ||
i dont know if i connected the yellow wires right. Anyone knows where to plug/wire the yellow wires to or a pic of the wiring?? |
#15 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
i think this is when a relay comes into play.im assuming the yellow is the accessory wire which runs 10v "which cause the flicker" until u actually turn ur headlights on for it to run 12v...
this is the reason why i dont have hid on the headlight yet.. |
#16 |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
Did you register just to bump a year and a half old thread? o_O
-SAV
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#17 |
![]() ![]() Drives: 2009 Toyota Yaris Hatchback Join Date: Jan 2011
I love how some expensive, luxury cars have that bright, pure white light. I am a newbie, and I don't make a lot of money either so for me to go after HID is a bit over my price range. But, I searched for a way to get the same effect without an expensive modification,
I found these bulbs online from an eBay salesman that had some pretty good reviews. ![]() Purchased for 16$ And went to my Mechanic to install the bulbs, he did it for 10$ so I tipped him too. ![]() ![]() My headlights were kinda dirty when I took the pictures but as you can see I got that white look that I so desired. All for just under 30$. I wouldn't say that they are a lot brighter but then again I live in NYC and brightness was not what I was looking for. *As a side note, there are small lamps on the side of the headlights that are still yellow, does anyone know what kind of bulbs they are? and where to get white or blue colored bulbs to replace? |
#18 |
toyota
you should have went with hid... those bulbs wont last very long..so in the long term hid might be cheaper..there about $70 a set right now maybe cheaper.
