#1 |
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
I actually ordered from Garm at Micro Image. I ordered the NST SSK under hood "short shifter kit". It took me a total of 3-4 minutes to install only because it was a little harder to get in place that I first thought. If I did it again it would only take me 1-2 minutes.
Its a great mod and I really dont see the need to get any of the other stuff, but thats just me. FYI, give yourself a week or two to get used to the new shifter feel. Its strange at first, but its really nice now. I ordered the 13mm rear hub spacers at the same time as my SSK. Both arrived in the same box about a week after ordering(from MicroImage).
Its all about the MPG's !! |
![]() Drives: 3dr hb Join Date: Aug 2010
fyi
I thought I'd share my experience, and let you judge for yourself. If you install the piece over the shift arm under the hood alone, you will definitely notice the shifting will be slightly harder, and takes more effort to get the shifts into the gears.
If you order the Toyota part, you get a bracket, in addition to the cable/lever piece, that moves the cables upward,which helps prevent the binding caused by the movement of the cable attachment about an inch higher than stock. I believe it is WELL worth the extra $20-25 for the bracket. It's a really neat machined aluminum piece, but is a bit of a pain to install... just sayin'! |
#3 |
Does any one recommend it with the twm in-cabin short shift? Cuz I have the twm in-cabin shifter and it is awesome in my opinion
#4 |
![]() Drives: yaris hatch back Join Date: Oct 2010
any one have pics of install i got one but dont know where it goes
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
#6 |
ok so i tried it agien and the rubber piece is ripping but what looks even worse is it appers that the shaft on the shifter linkage has a shoulder for the washer to rest on. will the nst ssk fit over the small shoulder?
#7 |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
How i know if the NST SSK under hood "short shifter kit" fit to my 2009 Yaris sedan?
#8 |
#9 |
^ you have a 50/50 chance it will fit. toyota sources their linkage from two places starting in 2009.
IF it doesn't fit, you have to file a very small corner off of it and it will fit 100% after that. Here is the thread for the modification: http://www.microimageonline.com/foru...09-2010-models
#10 | |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
on backorder... FML
#12 |
^ yep, sorry about that, my understanding is that NST will be producing more after the first of the year.
#13 |
WHAT!!! holy monkey balls... that sux.. i just got "got"... thanks for that update though. ill be waitings... is that the same for the front tow hook also?
#14 |
The NST front tow hook will never be reproduced to my knowledge.
#15 |
![]() ![]() Drives: 2008 toyota yaris Join Date: Mar 2011
is this still going to avl. after the first of the year?
08 toyota yaris with some big tires lol 02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
#16 |
If it's not, someone else is producing the same thing:
Micro Image Short Shift Kit I installed one a while back and it works like a charm. (Link in my signature...)
| NST (NonStopTuning) Pulleys. Info, Specs, User Data... | NonStopTuning | Performance Modifications | 636 | 12-13-2013 09:47 PM |
| NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 245 | 08-28-2007 03:53 PM |
| short shift: NST or TRD? | cali yaris | Performance Modifications | 21 | 07-07-2007 03:38 PM |
