Old 04-04-2009, 01:58 AM   #1
^ did you have forged rods in your old one? I may need them...
no.. it's stock.
Old 04-04-2009, 02:32 AM   #2
dudes.... the goal is 300whp and knowing Garm, he won't quit till he reaches it
Old 04-04-2009, 03:38 AM   #3
jkuchta
Drives: 2007 Yaris hatch (red)
My bet is 315 AT THE WHEELS....then he'll need larger diameter wheel studs!
jkuchta is offline   Reply With Quote
Old 04-04-2009, 09:03 AM   #4
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
oh no, im guessing 203whp on the stock motor...
His built one I guess will have 325whp
Old 04-04-2009, 11:53 AM   #5
^ I think the question is how much she'll make with the stock motor, before the swap.
I tell you what, after the initial tune, when we swap motors, I WILL run a poll with a prize for the final number on the built motor.
Old 04-04-2009, 09:43 PM   #6
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Hey garm I am still not understanding why you upgraded the throttle body and intake mainfold to that of the xB?
Old 04-04-2009, 09:50 PM   #7
The xB is a cable throttle, the Yaris is drive by wire (electronic throttle). To use the AEM standalone management effectively, we needed to change the throttle to cable.
Plus, I really LIKE throttle by cable, super responsive and tunable.
Old 04-04-2009, 11:20 PM   #8
Parmas
Parmas's Avatar
Is the throttle body diameter of the XB equal to that of the yaris? Is there any other differences in between and why the XB is cable throttle and the yaris by wire, is there any purpose?
Old 04-04-2009, 11:35 PM   #9
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Here is what I know about cable throttle bodies vs drive by wire systems:
Cable throttle:
-Very responsive and has been used for many decades.
-Connected to the gas peddle by a series of pulleys.
Drive by wire:
-Smooth acceleration.
-There is also noticeable lag when you press on the gas peddle because the computer has to tell the ECU how much the throttle has to open; not as quick as good 'ole cable throttle.
-Take a look at the gas peddle on a Yaris. Notice anything? There is a box to which a peddle sits in, connected to some electronics which lead to the ECU.
-When you drive over some speed bumps and you press on the gas peddle a little bit, the car wouldn't jerk or move violently in the event of sudden acceleration. This is meant for driving comfort.
Sponsored by: Micro Image
http://microimageonline.com
Old 04-05-2009, 01:20 AM   #10
Parmas
Parmas's Avatar
Cable throttle:
Drive by wire:
THanks for your reply it is something that I didn't consider.
So if I consider to upgrade to cable throttle what parts exactly I need and how can I know if the ecu supports this feature?
Old 04-06-2009, 12:34 PM   #11
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You already have the throttle by cable!!!
Old 04-05-2009, 11:36 AM   #12
what ECU do you mean? The stock ECU will not handle DBC
Old 04-05-2009, 12:44 PM   #13
Parmas, are you sure you don't already have a cable throttle? As far as I know the echos/first gen yaris didn't have drive by wire yet...
Old 04-06-2009, 11:32 AM   #14
UPDATES 4/6:
The GT28 turbo is installed, replacing the GT25. The AEM a/f gauge is wired.
Just some piping and then modding the AEM box for vvt-i and we are ready to fire it up.
Old 04-06-2009, 11:38 AM   #15
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Excellent, best of luck Garm!
Wanted: Forced Induction
Old 04-06-2009, 11:40 AM   #16
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Garm, did you size your fuel pump based on the HP you expected to output or did you just select the largest one they offered of that type?
Old 04-06-2009, 02:17 PM   #17
Carvin'07
Selling all mods
Carvin'07's Avatar
Drives: '07 Bayou Blue - totally stock
That is the largest that Walbro makes. IIRC, there are many Bosch pumps that flow enough fuel for much more stupid amounts of power, but they are much wider and will not fit the spot in the stock tank (picture is back a couple pages). Plus their low pressure performance is crap.
In any case, the Walbro 255lph pump is still capable of flowing TONS of fuel, in fact for over 500 whp. There are other constraints such as the filter, lines, rail, etc that limit it.
-- stock --
Toyota CD player (mint) for sale see thread in For Sale section
Carvin'07 is offline   Reply With Quote
Old 04-06-2009, 04:09 PM   #18
CASTREX
CASTREX's Avatar
The Walbro 255 is pretty much the standard pump that everybody uses and capable of supporting lots of power.
Is good quality and cheap...
There are not that many options in regards to flow capacity....
If you are making anything from 100 hp to 500 hp a Walbro 255 will work for you. You don't really need to match the pumps preassure capacity to your fuel needs. That is the job of the FPR.
You only need to worry to have a pump that will supply enough fuel... and since a Yaris will never push 500hp and walbro is all you ever going to need...
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Engine Swap / Turbo.... Sabretooth Forced Induction Forum 10 09-13-2007 06:23 PM
small update on turbo project... joey1320 Forced Induction Forum 26 08-03-2007 04:29 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
