Old 02-13-2011, 05:21 PM   #1
henry33
Drives: yaris1.33
I will be using 185/60 r15 and originally there was ET45
henry33 is offline   Reply With Quote
Old 02-13-2011, 06:33 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^You'll be fine with that set-up.
Old 02-14-2011, 03:09 AM   #3
henry33
Drives: yaris1.33
ok so I will buy those wheels most probably ;)
thank you
Old 02-14-2011, 07:28 AM   #4
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
I have 16 x 6.5 ET45 and I'm wondering if I can fit 205/50/R16 if my car is lowered by 30-35mm? I have the 1.8 Yaris which already has the steering lock reduced as standard to stop the 17" wheels rubbing, so it might be okay with this model?
PumpkinSteve is offline   Reply With Quote
Old 02-28-2011, 05:45 PM   #5
Yari5Love
Drives: 08 Polar White LB
Quick question thinking about buying some wheels but wasn't sure if they would fit my 08'Liftback the wheels are 4x100 bolt pattern&13x7 with a 15 offset anyone know if they'll fit without making any adjustments to the car? my car isnt lowered or anything just stock. please no flaming just a question I need answered. thanks
Yari5Love is offline   Reply With Quote
Old 02-28-2011, 05:58 PM   #6
kimona
kimona's Avatar
Quick answer: No, they won't fit.
Old 03-01-2011, 03:45 AM   #7
Yari5Love
Thank You!!!
Old 02-28-2011, 11:17 PM   #8
piranha0522
Drives: '06 Yaris
hmm..would this fit ok?
So I found a nice set of rims in my area.
They are 16" 4 bolt with tires 205, 45, 16. These would fit fine right?
I have an '06 5dr liftback.
What does everyone mean when they say offset? I still haven't figured that out.
Thanks!
piranha0522 is offline   Reply With Quote
Old 03-01-2011, 12:59 AM   #9
RedRide
RedRide's Avatar
Offset explained:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old 03-01-2011, 03:25 AM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
also bolt pattern. make sure they are 4x100.
Old 03-03-2011, 04:30 AM   #11
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Just a quickie here, can going from factory size (180-60-15) to a slightly taller sidewall (185-65-15) be afforded without rubbing?
Midnight Drifter is offline   Reply With Quote
Old 03-03-2011, 12:38 PM   #12
kimona
kimona's Avatar
You should be fine with 185/65/15's. Post a pic if you decide to go that way.
Old 03-04-2011, 05:53 AM   #13
Midnight Drifter
Going Retro
Will do, the tires I have in mind have a very unique feature to them. Won't see any pictures for months though, still gotta wear out the stocks. ;)
Old 03-04-2011, 12:48 PM   #14
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Question
Tell us please!
(o:
CLA 250, 4MATIC
Old 03-11-2011, 04:02 AM   #15
Midnight Drifter
Going Retro
Tell us please!
(o:
You'll just have to see it when it's time to change my tires :)
Old 03-06-2011, 02:48 PM   #16
glhsracer
Drives: 2008 Sedan MT
Great thread, lots of good information. I have an 08 Yaris Sedan, I believe it has 185-50-15, car is not here so I can't walk out to check. I have a new set of 205-50-15 in my garage, do you think these would these be too much for the Yaris? I think it would look better with a little more tire but don't want to get too carried away. Any advice would be helpful, thanks.
Glhsracer
glhsracer is offline   Reply With Quote
Old 03-06-2011, 05:35 PM   #17
derickveliz2
Exclamation
Glhsracer
In winter I run with 205/50/15, they look great if your car is lowered, performance is awesome. The Diameter is less than OEM (smaller tire) speedometer will read about 3% faster than actual.
D.
CLA 250, 4MATIC
Old 03-15-2011, 01:52 PM   #18
derickveliz2
FYI....
My snow tires didn't like the negative camber )o: on rear end.
D.
CLA 250, 4MATIC
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
