Old 05-22-2009, 02:52 PM   #1
By the way, I have an extra set of brackets.
If someone doesn't have to tools, or doesn't understand the grinding process to move the HU deeper, so the trim piece will fit with wider HUs, I can modify the set that I have and ship it to you in exchange for your set.
CTScott is offline
Old 05-22-2009, 08:12 PM   #2
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
Still doesn't work due to the cover it the same size as the pionner unit. Because of pionner stupid din size i had to trim the double din metra brackets so it could fit. Guess i'm stuck with the 200mm opening. Unless i change the cover pocket to an open version. But then i'll have items out in the open which i don't like.
Adriaan is offline
Old 05-23-2009, 04:13 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
How do you grind the positioning stubs? Will a dremel w/ a sanding head do it?
All I have to do is grind down all of the positioning stubs on the sides of the bracket that face the head unit, right?
IsLNdbOi is offline
Old 05-23-2009, 06:48 AM   #4
I used a file to remove the stubs. Dremel will work as well. The metal is very soft and easy to remove.
Yes, all you have to do is eliminate all 6 stubs on the HU side of the bracket.
WeeYari is offline
Old 05-23-2009, 12:05 PM   #5
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I used one of those big spinning stone griding wheel things.
Sodium Duck is offline
Old 05-26-2009, 06:05 AM   #6
IsLNdbOi
IsLNdbOi's Avatar
Finally got it in. For my Pioneer I used my dremel to grind down all six of the positioning stubs. Then I moved the brackets forward until the top front hole was over the front-most screw hole for Toyota mounting points on the Pioneer HU. The top rear hole is now over the hole where the top rear positioning stub used to be.
In this mounting position, I use one of the original mounting bracket screws for the front hole and a short, self-tapping screw for the rear hole (the one that used to be for the positioning stub):
This is the best I could get it. The front bottom edge of the HU is flush / right up against the bottom edge of the new trim piece. The front top edge of the HU is further back so there's a small gap between that top edge of the HU and the top edge of the new trim piece. I'll have to cut the top edge of the stick on bezel that the Pioneer HU came with so I can stick that to the top edge of the front of the HU. Should take care of that gap.
With this new trim piece and the way I had to mount the HU, the HU now sits further back so it's more recessed. I like how this looks.
Scott, I still need another one of these trim pieces. One of my friends has asked me to install a new HU in his Yaris and he wants me to get one of these for him. Please keep me on the list for your next possible group buy.
IsLNdbOi is offline
Old 05-26-2009, 10:42 AM   #7
One is for sale here in Toronto.
http://www.yarisworld.com/forums/showthread.php?t=18204
WeeYari is offline
Old 05-26-2009, 10:49 AM   #8
I have a small gap at the top of mine which I was able to minimize to nearly un-noticable.
There is a small amount of up/down movement of the HU that can be realized via the 4 screws securing it to the dash assembly. Holding the HU in place with the 4 screws slightly loose, try sliding it up and down. You should notice that you will be able to raise the HU about 1/16".
Give it a shot.
WeeYari is offline
Old 05-26-2009, 08:30 AM   #9
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
^nice pic. find your screw lol!
808_Yaris is offline
Old 05-26-2009, 10:12 PM   #10
IsLNdbOi
IsLNdbOi's Avatar
I tried re-positioning the HU. Loosened the four screws holding the mounting brackets in then pushed up on the bottom of the HU to raise it as much as possible. While holding it up, I tightened the screws. Helped a little bit, but the gap was still very visible. So, I took that plastic trim pieces that comes with the HU and cut it up so all I had left was the piece that goes along the top edge of front of the HU.
Looks better now:
IsLNdbOi is offline
Old 07-05-2009, 09:54 PM   #11
paulort
Drives: toyota yaris hatchback(black)
is it possible to ship it to philippines?
paulort is offline
Old 07-06-2009, 07:48 AM   #12
I'm all out of the ones from the group buy at this point. From the Philippines you would probably be able to order the part from a Toyota dealership in Australia (I believe that the Toyota Follow-me package is offered as an option there). If not, it's readily available from Europe.
CTScott is offline
Old 08-06-2009, 08:50 PM   #13
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
I'm down for 1 as well. I'm planning on putting in a new stereo here soon.
I just want to double check that this will work for a 09 Yaris Sedan, correct?
Reeves360 is offline
Old 08-06-2009, 08:54 PM   #14
No. The sedan's radio trim is different than the LB's.
CTScott is offline
Old 07-06-2009, 11:38 AM   #15
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
I have one up for grabs...US$55.00 shipped (US)...pm'd me if interested...
Don't be threating me with a good time!!!
anubisx99 is offline
Old 07-06-2009, 10:07 PM   #16
paulort
ah,okay.thanks for the info. :D
paulort is offline
Old 08-02-2009, 08:30 AM   #17
DED1982
Drives: 2008 Absolutely Red 2 Dr Hatch
Send a message via Yahoo to DED1982
dannnnnng
I can't believe I missed the group buy. I REALLY need this piece! Anyone want to sell me theirs, or start a new GB? Thanks in advance
Doug
DED1982 is offline
Old 08-02-2009, 09:01 AM   #18
Doug
I am actually getting ready to do another European order, and I am going to grab a few more of these in the process.
CTScott is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
