Old 07-09-2012, 09:18 PM   #1
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
can't wait to see it and Garm's version :D!!!
Interior:ALL red, black roof
Old 07-09-2012, 09:25 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Same here... what happened to Garm's manifold.
On the 17th, I'll be holding in my hands all the parts to make it happen. After that the next step will be taking it to the welder, and then test fitting it on the engine. I'll be sure to post pics and videos of everything as it happens.
Old 07-09-2012, 09:32 PM   #3
We got the final version to fit on our motor-on-a-stand, which it did. Now we're waiting on a pre-production version we can put on a test car and go dyno.
Old 07-09-2012, 09:34 PM   #4
tooter
play every day
tooter's Avatar
That's cool, Garml!
We're running neck and neck.
This is getting exciting.
Old 07-09-2012, 10:00 PM   #5
packetrace
packetrace's Avatar
This is sick!!! Cant wait to see it :-)
Old 07-09-2012, 10:11 PM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Im eggzited
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-09-2012, 10:20 PM   #7
tooter
play every day
tooter's Avatar
Here's the flange as the grooves are being created so that the stock Oring gasket will fit right on.
Old 07-10-2012, 07:47 AM   #8
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Excited to see this as well!
4/20 NEVER FORGET is offline   Reply With Quote
Old 07-10-2012, 07:52 AM   #9
packetrace
packetrace's Avatar
This is even better tooter :-)
Old 07-10-2012, 10:52 AM   #10
tooter
play every day
tooter's Avatar
The idea is to replicate the OEM design as close as possible, so that I can simply bolt it on without needing to make any alterations or adjustments to anything else.
The throttle body adaptor will be grooved in exactly the same manner so as to accept the stock Oring base gasket...
Old 07-10-2012, 10:20 PM   #11
tooter
play every day
tooter's Avatar
Here's the flange with all of the OEM gasket detailing... groovy!
Old 07-15-2012, 06:55 PM   #12
XFACOR
Drives: 1nz-fe
Here you go all billet.
Right-hand side inlet, shorter turbo piping = faster spool up. And a 70mm Wilson Manifold T/B
XFACOR is offline   Reply With Quote
Old 07-15-2012, 07:49 PM   #13
tooter
play every day
tooter's Avatar
That is absolutely beautiful detailing on your runners and their stacks, man.
Mine are quite a bit more primitive...
...but on Tuesday I'll have this...
to attach to this...
Old 07-15-2012, 07:07 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
just shakes head...
Tooter man you are crazy. can't wait to see what your final results are.
Colin Chapman disciple
Old 07-15-2012, 07:57 PM   #15
tooter
play every day
tooter's Avatar
Same here.
I already have a pretty good idea how this will all shake out. Lose some bottom end for sure while maybe gaining a little bit at the top end. But since this is totally uncharted territory... no one knows yet how much of either so that's what I'm aiming to find out for myself.
Old 07-16-2012, 02:52 PM   #16
malibuguy
Obsessed with 1.5L
i used to weld intake manifolds like whats on TBRs car, but for 2JZs & 2RZs...the head flange, runners & plenum baseplate had to be tightly placed/sammiched in a jig...3/8" thick steel plates on either side with 1/2" thick all thread bolted thru each runner.
With alternating welds on each runner, I would get virtually no warpage at all...requiring at most the slightest kiss on a belt sander to true it up
of course with the 'rolla intake...you cant use a jig like that
-96 Tercel 4dr
Old 07-17-2012, 08:55 PM   #17
tooter
play every day
tooter's Avatar
We talked about the welding issues today...
...while the flange was being made...
There's more pics and lots of video that I'll be uploading time permitting.
Old 07-17-2012, 09:51 PM   #18
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
shinny
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
