Old 05-22-2014, 01:15 AM   #1
TerenceCruz
Drives: 2011 Toyota Yaris
Originally Posted by ezhacker1 View Post
9K/9k Stance 6in springs.
yeah keep preload to a bare minimum, least for the front. The rears, actually you cant preload it, because moving the strut body just moves amount of shaft travel. But still you can bust a strut .
You cant get any more lower/higher than what the springs/ spring perch / lock rings give you or lack there of. So trying to thread that rear strut lower, wont give you more low. The front yeah, the shock body adjusting will control the car height, and not the spring lock ring.
Ahh gotcha. Guess I gotta leave it alone for now until I get those springs. They're shorter right? That way I can add the locks/perches and still go as low?
@terrence I cannot tell the difference lol. Also do not shorten your shock much more. All of us with Megans who went too short with out shock length wound up blowing the shock.
Really?? Haha damn I hella see it. Definitely man I won't be touching them. I'll have to deal with it until I get shorter springs. So I'll be okay if I leave it where it is?
TerenceCruz is offline   Reply With Quote
Old 05-22-2014, 03:13 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Yeah, measure your springs should be 7in. I have 6in stiffer springs. Basically measure how much your rear springs compress compared to its free length. You can calculate how much drop any spring will give with stated spring rates.
Course you could go with same spring rate but shorter springs.
Check out my Build thread:
Old 05-22-2014, 01:57 PM   #3
TerenceCruz
Sweet. Thanks for the help man. The ones I'm looking at are - 6k 150mm / 336lb 6in. Looking for the pair with 9k spring rates. I was thinking about just changing the rear springs.
Old 05-22-2014, 06:29 PM   #4
ezhacker1
ezhacker1's Avatar
Yeah, seeing they are sold in pairs you can test to see how much drop front and back you can get. I do recall I only decided to buying the 9k 150mm once i saw they had it (gotta keep checking or maybe just ask them), i bought a pair of 8k 175mm (7") to test.
I only went with the 9k, because i calculated it would allow me to lower a bit more (i forgot the number) and still be at the same height compared to 4k when fully loaded with passengers. Be warned that 9k, is pretty stiff.
Old 05-23-2014, 08:14 AM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
@ezhacker1 regarding your post about shortening rear shocks for preload/length. If you have the shock too long and once lowered at ride height the inner valve pushes down pretty far towards the bottom of the inner tube, wouldnt you call that preload too?
Also if the shock is set so long that once the car is lowered to its static height if the valve is resting agains the inside of the bottom of the tube, wouldnt that hold the car up anyways? in that case, shortening the shock would allow the valve to move back up the inner tube at static height and then that would allow the car to settle down more.
just like discussing these things with other suspension experts lol
Old 06-02-2014, 02:14 AM   #6
ezhacker1
ezhacker1's Avatar
i read and re-read this a few times. LOL gets confusing. Front is easy to visualize how the whole system works, rear takes alot of my brain cells HAHA.
This is just my understanding of how suspension works.
The front shocks have preload abililty which is just pre compressing the spring even before the car is on the ground, but that spring will push against the shock hat, tugging on the shaft
The rear struts need to be set up in such a way at static load with wheels on ground that the shaft has enough travel both up and down without bottoming out. I measured static shaft length, compared that to how much shaft is left with car on ground, and calculate at max load how much more the shaft will travel. Then i adjust the strut height accordingly, making sure that with wheels off ground the spring and perches don't fall out.
Old 06-01-2014, 10:36 PM   #7
TerenceCruz
Tested the cars ABS today. Yup, as of right now no ABS.. Lol. I gotta figure out what happened to that and the Vehicle Stability Control already. Those lights on the dash are not fun to look at. A friend of mine told me that if we did stretch the wires out on accident it will be costly to replace.. *sigh*
Old 06-02-2014, 01:26 AM   #8
lol, you don't needs ABS or VSC anyway
Old 06-02-2014, 02:56 PM   #9
TerenceCruz
Hahah maaan, I'd like to keep those features though
Old 06-02-2014, 02:58 PM   #10
TerenceCruz
right, so in the rear you have some preload to keep the spring taught even with wheels in the air, mine i have way longer. I have never bottomed mine out, when they were short I topped them out all the time.
I was considering shortening the shock to see if it was holding me up at all, but with my recent mods my fitment is perfect so idc now haha
Haha I'm still trying to absorb all of this since I consider myself a noob when it comes to the way the coils can be adjusted. When I lift my car from the rear the springs just fall out.. Haha. The weight of the car is keeping them in place when it's on the ground.
Old 06-02-2014, 07:15 AM   #11
1.5
Form>Function
1.5's Avatar
Old 06-02-2014, 04:03 PM   #12
ezhacker1
ezhacker1's Avatar
Well to a certain extent the strut height should keep the spring assembly from falling out, but if you take out perches rings, or swap to shorter spring length then depends.
Ill look at your car at the coming up meet.
Old 06-02-2014, 04:35 PM   #13
TerenceCruz
Sounds good man. Thank you. You have an 09+ Yaris right? So you have ABS and VSC?
Old 06-02-2014, 07:40 PM   #14
ezhacker1
ezhacker1's Avatar
ABS yes, VSC no.
Old 06-03-2014, 12:12 AM   #15
TerenceCruz
ABS yes, VSC no.
Ahhh okay. The ABS light didn't give you any problems at all when you installed the coilovers? Did you unplug the sensors or anything during the install? I'm just trying to figure out what may have caused the lights to go off cause I thought we did a good job about avoiding messing up the wiring.
Old 06-08-2014, 05:14 PM   #16
TerenceCruz
So a friend of mine told me the reason why my ABS and VSC lights stay on now is because the car is too low for the sensors to get an accurate reading. I have to get "extensions" for the sensors supposedly. Still gotta do some hw but what he says does make sense.
Old 06-09-2014, 06:52 AM   #17
1.5
Form>Function
1.5's Avatar
haha nice
Old 06-09-2014, 04:18 PM   #18
TerenceCruz
haha nice
Haha it sucks though man, I looked online and I can't really find any info about the wire "extensions"
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 12:25 PM
2012 Vitz from the 2011 Tokyo Auto Salon CTScott Third Gen Yaris General Discussion 14 02-10-2011 08:06 AM
Is UA-NCP13 1.5L Manual Trans a Vitz RS? WesSunday General Yaris / Vitz Discussion 1 11-28-2010 10:47 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
A German Yaris/Vitz/Echo ;) we-to-11 Photo-Video-Media Gallery 5 06-27-2007 08:26 PM
