#1 |
![]() Drives: 2010 Yaris 3D LB Join Date: Jun 2010
I just finished a 1000 mile trip with the 2 button cruise control and I liked it so much that I upgraded to a variation on the 4 button version. While on the road I picked up a MOMENTARY-OFF-MOMENTARY toggle switch (at HSC Electronics in California, $1.49). I now have Up=RES/+ and Down=SET/- on the switch, a low profile Microswitch push button for On/Off and a C&K white pushbutton for Cancel.
By using 3 differently shaped controls, I can feel the difference, so I don't need to be able to see them. I had the push buttons in my stash. The toggle switch is similar to this: http://search.digikey.com/scripts/Dk...name=EG2388-ND Note also this is a 2010 Yaris automatic, stripped down (no power package), and it had the cruise control wiring in place. |
i have one question here.
My yaris D3 connector has one cable (black). When i remove this connector, the horn stops working. is it the horn connector ? what kind of power does this cable provide. Negative or positive ? also the pin 40 on the ECM doesnt contain any sort of power when i check it with a power meter. Is it supposed to have any pulse or something? i am just a little worried to not damage the ECM by doing this sort of a setup. Is it safe ?? 100% ?? :p
---- its fun to be in a vitz! |
#3 |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Scott... It appears for my 08 CND Sedan, the wire run from the ECU to AD4 is there, and what is missing is the wire run from AD4 to D3..
Since AD4 is tucked way in the top left side of the inner dash, not sure if you have ever taken apart your Yaris's top dash, and if you have noticed if both ends of AD4 have the light blue wire.. I am really hoping Toyota has the wire run from AD4 to D3, but only decided to tuck away the run from AD4 to D3 some where. I would find it odd that all of the other wiring is there as even the clutch switch is there, but they manufactured the wire harness with only missing the run from AD4 to D3 What do you think? Last edited by CB900F2; 08-08-2010 at 04:37 PM. |
#4 | |
Getting to AD4 requires removing the top of the dash. The wire from AD4 to D3 is definitely not tucked, as it would be part of the harness that also contains the horn wire. |
#5 | |
Check out this thread for more info: http://www.yarisworld.com/forums/sho...ght=faq+cruise |
#6 | |
#7 |
also i have got a Yaris sedan (BELTA in japan) . got 3 wires in D3 connector. Got it also from JAPAN. can i do the CC with both these cars ??
#8 | |
For the other, which just has the black wire, the best quick test is to measure the voltage on the ECM pin (A21-Pin 40) with the ignition on. If CC is active on the ECM, then that pin will have 12V on it. |
#9 | |
#10 | |
#11 | |
#12 |
![]() Drives: 08 Black Liftback S Join Date: Jul 2010
Hello!
I have a question, I hope you all don't mind.... I have an 08 liftback, MT, without wiring. I've installed the buttons and the wiring to ground and ECM. I don't have a harness for the clutch switch, so I need to rig the switch to go into the fuse box in the engine bay. (If this is wrong please correct me) The clutch switch has two contacts, so I assume I run two wires off of those contacts into the fuse box. My question is which wire goes where? Looking at the picture on the top of the 4th page of the pdf, I'm not entirely sure. |
#13 | |
Correct on the clutch switch wiring. The clutch switch goes to the blue wire indicated below and the white wire, to pins to the right of the blue. |
#14 | |
So both wires from the clutch switch splice into the blue wire and the white wire is moved to the right of the blue? Last edited by Daren; 08-12-2010 at 10:13 PM. Reason: The internet has made me dumb. |
#15 |
No, one wire from the clutch switch connects to the blue and the other connects to the white.
#16 |
Thank you so much.
#17 |
Drives: Sedan 2009 Automatic Join Date: Aug 2010
Would this work on a 2009 Sedan?
#18 |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
