Old 07-21-2012, 01:08 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Nope.
There are a lot of really nice options for finishing the manifold, and I'll be choosing one of them. In my opinion, wrapping looks crappy, so obviously I'm more concerned with looks than performance.
Old 07-21-2012, 05:03 PM   #2
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
looks good
goliath1812 is offline   Reply With Quote
Old 07-21-2012, 05:29 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
that beats the crap out of the original plastic manifold (not a fan).
did you get the throttle body plate done yet?
Old 07-21-2012, 06:28 PM   #4
tooter
play every day
tooter's Avatar
Yeah, it gets lots of bling points even if it doesn't work. I'm doing this as much for that really cool Formula 1 look as much as for any of the other reasons.
Yes, it's done. I pick it up on Monday, and will post pics when I get it home.
I took the prototype flange and drilled and filed and Dremeled all of the peripheral clearances into it so that the new measurement data can be taken off of the corrected part and fed into the CNC machine for the finished version.
Old 07-21-2012, 07:19 PM   #5
Billiam
Drives: '10 White Yaris 4D LB
Not to be a party pooper...but haven't you basically voided your warranty on just about anything that would pop a CEL?
If you want to enjoy your car, stay off of the internet.
Old 07-21-2012, 07:52 PM   #6
tooter
play every day
tooter's Avatar
Originally Posted by Billiam View Post
Not to be a party pooper...but haven't basically voided your warranty on just about anything that would pop a CEL?
I'm a fuk warranty kind of guy...
...and am happy to assume all of the responsibilities of owning a new vehicle. I don't buy used vehicles either... always new ones.
Old 07-21-2012, 08:08 PM   #7
Billiam
I can respect that.
Old 07-21-2012, 06:11 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That's a rockin' setup!
Nice job.
Old 07-21-2012, 07:25 PM   #9
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
if it pops a CEL then he puts his OEM parts back on, resets the ecu but disconnecting the battery, and goes on. as far as warranty, it is amazing what can be done to car with out voiding it and in general you can get away with a lot of simple mods for intake and exhaust it just depends on if they can prove that any problem that arises is a direct result of the mods applied.
Old 07-21-2012, 09:31 PM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Looks flippin awesome on there!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-21-2012, 09:52 PM   #11
anomoly40
Depot Damager
Drives: '08 Liftback
Wait...that wasnt the final piece? Can i revise my numbers? Didnt know you were going to pull the old switcheroo... :)
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 07-21-2012, 10:00 PM   #12
tooter
play every day
tooter's Avatar
Sure.
You can change your guess any time right up until I do the dyno run.
It would have been the final piece, but the flange had some fitment issues that needed refining so I resolved them today and the CNC guys will make a corrected part next week.
Old 07-22-2012, 11:32 AM   #13
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Was it the bolt hole alignment, or perimeter clearance?
Old 07-22-2012, 12:08 PM   #14
tooter
play every day
tooter's Avatar
It was perimeter clearances. The top of the flange needs to be milled down 1mm to clear the stock fuel rail supports. It's really close, as I was able to drop in the flange easily just by slightly loosening the fuel rail bolts. There is a cylindrical sensor close on the left side so I filed a semicircle to clear it. Also at the center of the fuel rail there's a part underneath it which also needed a semicircle filed to clear.
They were minor and corrected with a file. The goal is to make the flange simply drop in.
How are you doing on yours? I hope that sharing the details of the process will help to move your manifold along.
Old 07-22-2012, 01:42 PM   #15
CrankyOldMan
Aah, I hadn't measured any of the surrounding areas, just guessed at the perimeter measurements.
Mine is pretty much shelved until I'm ready to do engine management--I'm not interested in fighting the ECU--but that will allow me to do cable throttle and a custom intake/exhaust setup. Then again, if your project works out as a net gain, I may just press on ahead with it.
Old 07-21-2012, 10:04 PM   #16
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Looks great! Are you going to bling it up with a polished fuel rail?
-Type 07 FFL-
My odometer 03/11
Old 07-21-2012, 10:11 PM   #17
tooter
play every day
tooter's Avatar
I'm a linear one-step-at-a-time person, and only focus my attention on what needs to be done right now.
I'm still at #1.
1. Flange Fit.
2. Throttle Body Fit.
3. Weld.
4. Blast.
5. Clean.
6. Dyno.
Old 07-22-2012, 08:08 AM   #18
Billiam
1 million HP.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
