Old 11-29-2010, 05:29 PM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
My computer cuts fuel at 115mph. Its like hitting a brick wall. Has anyone bypassed this problem yet. I want to pin this speedo
Old 11-29-2010, 08:16 PM   #2
cdydjded
Drives: Yaris LB Turbo
We all have th same issue. I too want to go past the 115 limiter. Someone here install an HKS speed cut limiter remover but Iv not received a concrete answer if it worked or not.
cdydjded is offline   Reply With Quote
Old 11-30-2010, 10:45 AM   #3
pimp my yaris
C'est la vie
I can now say for sure my problem is fixed. No more smoking out my neighbors while my car warms up. And my co-workers cant call my Yaris a bug fogger any more. Glad it was a easy fix.
Old 11-30-2010, 01:18 PM   #4
Focus_Sh1ft
Focus_Sh1ft's Avatar
Awesome. I'm gonna follow suite when the semester ends.
How's your tune holding up though? I'm still having weird richening problems.
Old 11-30-2010, 03:00 PM   #5
cdydjded
Old 11-30-2010, 04:48 PM   #6
pimp my yaris
C'est la vie
[QUOTE=Focus_Sh1ft;537902]Awesome. I'm gonna follow suite when the semester ends.
How's your tune holding up though? I'm still having weird richening problems.[/QUOTE
The oil line may be causing your oil in the intake problem. My tune is working ok, but I still need to get some bigger injectors. I always shift early to avoid going to lean.
Old 11-30-2010, 05:14 PM   #7
Focus_Sh1ft
Thanks for the pics
Yeah I really can't explain what's happening. Suddenly my tune was a whole point richer than what I had tuned for. Today I reset codes, plugged in the O2 sensor briefly, then unplugged it. Now I'm back at my expected AFRs. My O2 sensor might be shot as well because I got P2237 after it was in for awhile (open circuit). I've got another 2 years until emissions so no biggie
And Carlos, if both you AND Garrett end up being wrong about the return... I don't even know WHAT to think.
Old 11-30-2010, 04:28 PM   #8
pimp my yaris
C'est la vie
Pics Old location of drain is the brass plug
Old 11-30-2010, 05:35 PM   #9
cdydjded
Cmon! Its not just me & Garrett, its 99.9999% of the boosted world out there that have their returns above the oil line. Why must we piss against the wind?
Old 11-30-2010, 05:38 PM   #10
Focus_Sh1ft
So I'm the .0001%? I need to get with the times.
I was worried about the whole froth thing, because it did make sense, but after seeing this it's clearly a non issue.
Old 11-30-2010, 05:37 PM   #11
cdydjded
PIMP: Im glad you changed you set up. Noticed you are coming out of the turbo with a 90 deg, why dont you clock the cartridge so you could come straight out? It would be alot better.
Old 11-30-2010, 07:38 PM   #12
pimp my yaris
C'est la vie
If you check that artical from Garrett's web sight, at the bottom it says turbo oil inlet-outlet should be within 15 degrees perpendicular to the ground. I have my turbo clocked so its exactly perpendicular. Thats so oil does not pool in the cartrige. Could cause more smoke
Old 11-30-2010, 07:55 PM   #13
cdydjded
OK great, couldnt tell from the pic. it look like it was straight down to me.
Old 11-30-2010, 07:56 PM   #14
cdydjded
Pimp & Focus: did you guys mount your FIC's in the car or engine bay?
Old 11-30-2010, 08:44 PM   #15
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
let's hope in the car.
Old 11-30-2010, 09:03 PM   #16
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I was thinking of mounting mine in the front license plate area...that would be cool.....
if you believe this I have some awesome Ocean Front property in Oklahoma.
Old 11-30-2010, 09:13 PM   #17
pimp my yaris
C'est la vie
Mine is behind glove box door under dash. Their is a factory hole with a rubber plug just above factory ECM. This is where I ran my wiring. I drilled a second hole next to it for vaccume line to FIC.
Old 11-30-2010, 09:14 PM   #18
pimp my yaris
C'est la vie
What spark plugs are U guys running? And what gap?
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
