Old 07-13-2013, 05:00 PM   #325
Jadijkstra2000
Drives: Toyota Yaris 2010
Will this be possible on european toyota yaris 2010?
Jadijkstra2000 is offline   Reply With Quote
Old 07-14-2013, 08:10 AM   #326
Jadijkstra2000
Hmmmm got 89661-0dd90... No idea if it supports cc....
Old 07-26-2013, 11:04 PM   #327
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Doesn't cruise control usually consume more gas than without it? I would probably start falling asleep if I had it on for too long
07liftback is offline   Reply With Quote
Old 07-30-2013, 12:43 AM   #328
jose3sgte
Drives: Yaris Hatch,Celi 3SGTE,GC8
First of all thank you CT Scott for such helpful guide, I did it to my 06 PR spec Yaris and its been working like a charm for 6 months, I just have a question, Can I use a US S spec cluster (2010) to have the indicators working? I just ordered one from ebay.
jose3sgte is offline   Reply With Quote
Old 07-30-2013, 06:01 AM   #329
Unfortunately the indicator will not work unless you also upgrade the ECM to a 2009 or newer one as well.
I offer an indicator module, which can be used with 06-08 Yaris, which lack the cluster indicator. See my cruise control DIY below for more info on it.
Old 07-30-2013, 07:50 AM   #330
jose3sgte
Is the ecu plug n play? Or I have to look for one in particular? (US or PR spec), Thanks
Old 07-30-2013, 08:02 AM   #331
It is plug and play if it is properly matched. You would need a PR spec one. You would also have to match the car's features - Transmission type, engine immobilizer or not, ABS, Traction control, etc.
Old 08-12-2013, 09:26 PM   #332
Bammer
Clear, concise instructions. Close-up pics. Couldn't have completed the job without this info.
Thank-you.
Bammer is offline   Reply With Quote
Old 08-18-2013, 10:07 AM   #333
YarisBasic
Drives: YRX Black 4 doors seden
is anyone know, will the Rostra cc kit work on Australia model (2007) manual sedan,
Thank
Lewis
YarisBasic is offline   Reply With Quote
Old 08-18-2013, 02:38 PM   #334
Thank
Lewis
I am about 90% sure that the older (discontinued) Rostra kit will work with any of the non-US Yaris that do not have cruise control functionality built into the ECM. The newer kits definitely will not as they are just an overpriced version of the parts that I sell and require the ECM to have the functionality.
Old 08-20-2013, 09:05 AM   #335
YarisBasic
do you have the Rostra kit part no.? or do you sell the older kit?
Thanks
Old 08-20-2013, 10:39 AM   #336
Thanks
The discontinued Rostra kit was 250-1797 for MT and 250-1796 for AT.
I actually have one of the kits in my possession.
Old 10-09-2013, 07:09 AM   #337
Originally Posted by trionons View Post
Hi, I'm from the Ukraine and i have a 2012 Corolla, 1.33 1NR-FE. This version made in Japan only for Russia, Ukraine and other countries of the former USSR. Quation is simply: would cruise work on my Corolla? Because i now, that on 1.6 Corolla it work http://www.toyotaownersclub.com/foru...-instructions/, but in my case it not (( I can tell, I have tried to check voltage between ECM 40 Pin and Ground when ignition On, but result is 0v ! Maybe it not the fact, that ECM for Yaris and Corolla are same? But how to know which pin to check in Corolla 1.33 1NR-FE?
Do the connectors on the ECM on your Corolla look like the 2006-2011 Yaris connectors or like the 2012+ Yaris connectors?
2006-2011:
2012+:
Old 10-09-2013, 08:29 AM   #338
Look like 2006-2011.
OK. In that case from what I have seen of other Toyota vehicles that use that same connector (the Camry for instance), cruise control is pin 40 of the smaller connector as well. So, that means that you reading 0V on that pin on yours likely means no cruise control for you.
Old 10-09-2013, 09:16 AM   #339
Miserably, but I need to hear it from you to calm down ))
In other words: it just does not provide by the firmware ECM.
Anyway, good-bye cruise!
Unfortunately correct.
Old 11-24-2013, 08:27 PM   #340
exidus
Drives: toyota
Hi Guys,
Have been using the CC on my Thailand built Camry for almost 5 months now and enjoying every minute of it. Again thanks to CTScott.
exidus is offline   Reply With Quote
Old 12-28-2013, 02:45 PM   #341
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Hi Scott (or anyone else who might have some insight). My friend has a 2004 Toyota Echo 2 door Hatchback (non RS). He wants to know if there is a DIY Cruise Control method like this for his car as well. He really wants cruise added for his daily work commute. I told him if anyone knows it will be the guys on here.
white_rice is offline   Reply With Quote
Old 12-28-2013, 06:06 PM   #342
No. The Echo was cable throttle, so installing cruise control would mean adding a vacuum operated throttle cable actuator as well as the electronics to control it.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
