#1 |
Soon...sooooon...
![]() ![]() ![]() ![]() ![]() Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
I know. This stupid compressor is messing with my fun.
![]() Looking forward to the following on my first drive: 1) smoother, more robust acceleration 2) no clunks, clanks, knocks 3) cruise control testing
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
#3 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
One thing I will add based on my experience with the auto...
The ECM is adaptive, this means it will build fuel trim maps and shift patterns based on YOUR driving habits. My wife would drive my car most of the time, so when I got in it the car felt sluggish due to her conservative driving. Once I was able to drive the car a while, the performance feeling returns. |
#4 | |
I'm more of an accelerate fast, but not burnout kind of guy...at least since getting older. So, say, routinely running up close to redline at WOT off a ramp onto the highway for example shouldn't adversely affect either my engine or trans, then?
#5 |
Data doesn't lie
I use WOT regularly as prescribed by my physician
#6 |
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-06-2018 at 08:18 PM. |
#7 |
5 minute job removing the a/c compressor. The little plastic panel next to the radiator pops out easily with the removal of two plastic pins and creates a good sized window to the compressor, water pump etc. Excellent design on behalf of Toyota. I still think that changing out a water pump with the 2ZR shoehorned in there will be a royal pain in the butt.
#8 |
Data doesn't lie
#7
#9 |
First Drive Tonight!
Initial observations:
Much more refined feel. The engine is much smoother and the valve train is almost inaudible. The car pulls hard right up to about 6000 rpm before it shifts. Does it push you back into your seat? Not exactly, but it's definitely more potent than the 1.5. It's much more 'torquey', if that's a word. Shifting is precise. My little aging Yaris (with 180000 kms) now has an engine with around 70000 kms! Am I impressed? Damn straight! Please excuse both the mess and the crappy pic quality. ![]() I have a small exhaust clunk as the muffler, on some bumps and harder cornering is hitting the spring seat, but I think this is a quick fix when I get the exhaust work done. EDIT: The muffler is just turned a bit counterclockwise. My midpipe is in two sections (for shipping, I assume) so I just need to loosen the clamp, level the muffler and retighten. I expect that the new exhaust will allow the engine to breathe a little better. That oem muffler and piping is so tiny. The 'new' used ac compressor is virtually silent. As a major bonus, the cruise control is fully functional! So, to Tom, Trevor, Adam and Sam (not in any particular order), a huge THANKS for helping me through this!!!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-08-2018 at 01:00 PM. |
#10 | |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Agreed, it's not sports car level acceleration, but it's there all the way to redline. My favorite part is the way it loves to pull several hundred pounds of trailer and a hatch full of tools. =) |
#11 | |
#12 |
Data doesn't lie
I’m glad you took on this swap, we all learned something new and you now has a legit RS(nice badge!)
I wish I have a plaque or badge....or anything to give you as a welcome to the 2zr fam. But sadly I never had anything made |
#13 | |
#14 |
More legit...find yourself a TS badge. Got one in my garage but it's pretty beat up.
Sent from my EML-L09 using Tapatalk
#15 |
I really like that idea, WeeYari. I think I may start looking. Does that badge go in the same place as the RS badge and would it attach in the same manner?
#16 | |
Data doesn't lie
1nz built n/a 1nz supercharged 1nz turbo 1nz with 6 speed And 2zrfae swap 2zr with auto 2zr with 5 speed 2zr with 6 speed |
#17 | |
![]() There is this, but it looks like a peel-and-stick only. I would need one that attaches to the grille. https://www.ebay.co.uk/p/TRD-T-Sport...p2047675.l2644 Looks like I found the actual badge (Toyota 75301-52010) in the UK, but it will not ship overseas.
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I initially had a 2.5" and can confirm the loss in torque according to my butt dyno. I went back and got 2.25" and I'm all smiles now
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
