Old 10-30-2008, 10:50 PM   #19
1NZYaris1
1NZYaris1's Avatar
Originally Posted by IsLNdbOi View Post
Thanks for all the input guys. I've ordered the 48-LED light for both the cabin light and the interior trunk / hatch light. I'm going to see if I can shove one of these 48-LED boards into that hatch light area.
Still looking for bright, white LEDs that will fit into standard license plate holes in the front bumper. I need to find some that are water-proof.
All you need is 2 x T10 with the LED's of your choice as the number plate light
is weather proof .
I am already running 2 T10's with 4 Flux LED's on each. works and looks great,
Old 10-30-2008, 11:28 PM   #20
IsLNdbOi
IsLNdbOi's Avatar
is weather proof .
I'm not talking about the light for the rear plate in that post. My dealer drlled holes for the front plates even though I told them not to. Now I have two holes on my front bumper. The holes are thr standard size for license plate screws here in the US. I want to put a white LED in each hole and wire them to the paking lights.
Old 10-31-2008, 05:30 AM   #21
1NZYaris1
1NZYaris1's Avatar
there are some t10 water proof ones around , i will take a photo for you if you like. have about 4 prs sitting in the workshop
Old 10-31-2008, 08:25 AM   #22
IsLNdbOi
IsLNdbOi's Avatar
So T10 sized LEDs are the same size as standard license plate mounting holes in the US?
Old 10-31-2008, 07:51 PM   #23
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
arent the holes like a 1/4 inch or so
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-31-2008, 07:54 PM   #24
battleversiontc
maybe a 5mm led try measure the holes and go measure a 5mm led to see or a 10mm led at like radio shack if its one of those oznium.com sells them pre wired
Old 10-31-2008, 08:49 PM   #25
IsLNdbOi
IsLNdbOi's Avatar
Been googling screw sizes for license plates and it looks like American cars use 1/4" screws and I've been seeing 6mm and 6.3mm for Japanese (Toyota, Nissan, etc.) cars.
Old 11-01-2008, 10:20 PM   #26
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
Guys, the 48 LED board will NOT fit into the trunk area!!! Check my orignal post.
There is only 2cm x 4.5 cm worth of space. I cut a cardboard template of each light board before I ordered, based on the specs supplied form VLEDS. The 30 LED board is rectangular and will fit the trunk light housing. The 48LED is square and impossible to fit. The 48 LED board fits perfectly into the cabin light area, which has excess space to spare with a 7.5cm x 4.5 cm housing (approximately).
Meteorite_Marty is offline   Reply With Quote
Old 11-01-2008, 10:49 PM   #27
Meteorite_Marty
Some late night photography! Sorry for my crappy night pics... no tripod. Picures can only show so much. These lights really brighten up the cabin. I can actually see the floor and back seat area, with no shadows or ugly yellow. The white color is consistent with amongst all VLED lights, for all cabin, map, and trunk lighting.
Interior map (2 x 11 LED 194 bulbs) and cabin (1 x 48 LED board)...
Old 11-01-2008, 10:50 PM   #28
Meteorite_Marty
More pics of the trunk using the 30 LED board. No more ugly, dim, warm white/yellow incandescent bulbs!!!
Old 11-02-2008, 07:14 AM   #29
k3nn4
Drives: Yaris Sedan
Nice effect! I placed my order at v-leds :) thanks for the picture
k3nn4 is offline   Reply With Quote
Old 11-03-2008, 02:22 AM   #30
DerKaiZeRs
-YaRiS OwNeR-
DerKaiZeRs's Avatar
Drives: YRS Sedan
Hi meteorite.. so 48 LED board will FIT into the DOME light right?
coz I just bought LED from ebay and it doesn't fit into the DOME light because it is too Thick....
and what do u mean by 2 x 11 LED 194 bulbs that you put into the interior map.
Can you show me the type of that LED??
DerKaiZeRs is offline   Reply With Quote
Old 11-03-2008, 09:09 AM   #31
k3nn4
Drives: Yaris Sedan
"I hope you do read this post carefully.."
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
This is the one!
Old 11-04-2008, 02:16 AM   #32
DerKaiZeRs
-YaRiS OwNeR-
DerKaiZeRs's Avatar
Drives: YRS Sedan
Hi, Will I get a discount price if I fill in the Coupon Code when I try to buy several LED's from this site??
Old 11-04-2008, 05:34 PM   #33
k3nn4
Drives: Yaris Sedan
I think you should try the coupon code yourself..
Old 11-05-2008, 06:33 PM   #34
Meteorite_Marty
I think NISSANCLUB works for the coupon code. It is for $5 off.
Old 11-05-2008, 06:36 PM   #35
Meteorite_Marty
Yes, the 48 LED board fits into the DOME light (that is the one that goes off and on with the door opening). Naturally the board doesn't fit into the bracket where the festoon was. You have to run the dummy-festoon and wiring to the power clips, then mount the LED board somewhere in the plastic housing of the dome light.
Old 11-05-2008, 06:43 PM   #36
IsLNdbOi
IsLNdbOi's Avatar
All the coupons I've found (including the above NISSANCLUB one) are 10% off.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How do you replace the factory fog light bulb DjT DIY / Maintenance / Service 6 10-25-2008 07:24 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
Cheap LEDs Interior and Exterior jamal1984 Cosmetic Modifications (Exterior/Interior) 10 04-11-2007 11:08 AM
Yaris S Replace Fog Light Bulbs jamal1984 DIY / Maintenance / Service 1 01-13-2007 08:16 PM
