Old 01-26-2011, 04:28 PM   #19
tk1971
tk1971's Avatar
Anyone know where the "phone mute" or "mute" is on the Fujitsu Ten radio connector?
tk1971 is offline   Reply With Quote
Old 01-26-2011, 04:44 PM   #20
This low res image is a bit tricky to make out the pin numbers on, but mute is the bottom right pin (looking at the back of the radio) on the second connector from the left.
Old 01-26-2011, 04:59 PM   #21
tk1971
tk1971's Avatar
CTScott, thanks a bunch.
Old 04-21-2011, 12:28 AM   #22
stuck
Drives: Yaris 2007 Hatchback
I have a 2007 Hatchbacks. I need to know where i can find the parking brake wire in radio wire harness. I have found out that Yellow colored wire is coming from parking brake switch. but when it comes near DVD I can see 2 yellow wires. Which one is the parking brake wire is my problem. I have a NDDN-W58 model DVD player. what I need is to ground the parking brake wire so passengers can watch DVD while on the move.
stuck is offline   Reply With Quote
Old 11-24-2011, 01:37 PM   #23
CaptKirk
Drives: 2009 Sedan
Confused about wiring list for speakers.....
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- gray - yellow +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
What does all this mean? Is the LF pink positive or negative? Is the LR black positive or negative?
I can't tell from the way you've written this. Thanks in advance for helping!
I have an '09 sedan.
CaptKirk is offline   Reply With Quote
Old 12-02-2011, 09:57 AM   #24
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Are you installing speakers ?
Positive (+) Pink Negative (-) Purple
And so on ....
Old 04-29-2012, 01:01 AM   #25
johnbob
johnbob's Avatar
Just added amp to factory radio on 2010 3dr and the wiring scheme from BattleversionTC was on the money, may be variations between 3dr and sedan as noted in another post. Thanks B! Used Gray ignition wire to radio for amp turn-on not antenna wire which goes off as soon as you hit CD/AUX.
Custom (home-made) box for 6x9s in rear that drops into void between rear seat and cargo deck leaving entire flat deck when I need it. Pictures soon.
Thanks to everyone for numerous tips over the years.
johnbob is offline   Reply With Quote
Old 05-19-2012, 07:42 PM   #26
jasonmtl
Drives: 2008 HB yaris
same as mine,
I just upgraded mine, you are right, my 08 HB has the same color as grey + blue -
jasonmtl is offline   Reply With Quote
Old 08-19-2012, 10:29 PM   #27
creamy
Drives: 2008 toyota yaris
Smile Uber Noob
I am a super duper noob and i've installed subs before with aftermarket head units before in different cars but i want to install 2 12 inch subs in my yaris and i don't even know what colour cord is the 12v one to connect the remote cord up to so i don't drain my battery D:!.
Also with the RCA cables will i need to get an aftermarket headunit or is there a way to hook rca cables up to the OEM headunit ? D: thanks in advance :)
creamy is offline   Reply With Quote
Old 09-05-2012, 10:07 PM   #28
Tomatogrower
The Flying Tomato
Tomatogrower's Avatar
Drives: 2009 Red Yaris Hatchback
awesome! this will be a big help
Tomatogrower is offline   Reply With Quote
Old 12-30-2012, 09:46 PM   #29
Originally Posted by vandymach1ne View Post
Just bought a Pioneer AVH-X3500BHS DVD receiver. Going to be installing it myself. The highlighted text below - is this what I need to hook the parking brake wire from the receiver?
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer lt. green ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire green to purple + fuse box, top L, 30 pin plug, pin 12
Parking Brake yellow - fuse box, top R, 16 pin plug, pin 2 <<<<<<<<<<<<
Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Yes
Old 11-03-2013, 02:52 PM   #30
blotsome
I just replaced the stock radio on our 2006 Yaris 2 door hatchback (manual transmission, no power anything). The stock radio was a 86120-52490. The wire harness kit I got from Crutchfield had a 10 pin and 6 pin connector that worked fine with the wires that went into the stock radio. But there was an additional 20 pin connector (with a few wires in it) going into the radio, that do not have a corresponding place on the new, 3rd party radio. What on earth were these wires function, and is it detrimental that they aren't plugged into anything anymore? I was reading up, and I feel like maybe they had something to do with an aux jack, but there isn't an aux jack anywhere in this vehicle, to my knowledge. Thanks!
edit: found the aux jack (between the shifter and parking break).
blotsome is offline   Reply With Quote
Old 02-09-2014, 12:01 PM   #31
jazzyb88
Drives: 2009 Hatchback
Sorry to bring up this thread, but I noticed two plugs while removing my factory radio and can't figure out what they might be for? Here is a picture (they are taped to the stereo wiring harness).
Any ideas?
Below are the only plugs that go into my factory radio (radio, power connectors and steering control).
Thanks!
jazzyb88 is offline   Reply With Quote
Old 02-09-2014, 01:05 PM   #32
The 5 pin single row connector is for the navigation system and carries the parking brake, back up light, speed, etc. signals to the radio. The 8 pin black connector is for the phone microphone.
Old 02-10-2014, 10:31 AM   #33
jazzyb88
Thanks CTScott! :)
Interesting there is wiring for a phone mic...I wonder where that is supposed to be mounted? This makes me think that there is probably wiring present for rear speakers (I have a 3dr UK spec, which did not have rears). Might be a project for another time!
Old 02-10-2014, 11:33 AM   #34
Originally Posted by jazzyb88 View Post
Thanks CTScott! :)
The four pins in the white connector to the left of the blue one says that you do have wiring for the rear speakers (or at least from the radio to a junction connector).
Old 02-10-2014, 03:54 PM   #35
jazzyb88
Thanks
Old 04-09-2014, 06:27 PM   #36
tigobrata
Drives: toyota yaris
Hello, everyone, i just bought a toyota yaris 1.0 from 2007, and let me say, this post is a dream for anyone who just bought this car haha, i just have one small question if i may
in the radio wiring, in the cn700 conector, can anyone explain the function of pins 1 (CSLD-GND), 9 (TXM+), 10 (TXM-), 11 (ACC+B, i believe this has to do with the ignition no?) and finally 12 (BU+B)?
Thank you so much in advance, and again, great tips thus far :D
tigobrata is offline   Reply With Quote
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Factory wire harness or plastic aftermarket piece for aftermarket radio????? Yarisguy13 Great Lakes 1 09-17-2007 10:14 AM
Keyless Entry Wire Colors? Kaeon In Car Entertainment + Electronics (audio / video / alarm) 0 09-16-2007 02:39 PM
Radio Wire Diagram????? Yarisguy13 General Yaris / Vitz Discussion 1 04-18-2007 10:58 PM
