Old 11-11-2008, 03:59 PM   #19
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Us spec Yaris header is like this one
Originally Posted by rob323 View Post
Do your stock headers look like these from a 1.3 litre Echo?
Old 11-11-2008, 04:48 PM   #20
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Did you guys just get the 1.3 litre motor, or do you have those type of headers even on the 1.5 litre motors?
rob323 is offline   Reply With Quote
Old 11-11-2008, 05:49 PM   #21
CASTREX
CASTREX's Avatar
The only engine available in the US is the 1NZ-FE (1.5L)
You should be aware that there are some differences on external components between the 1.5L on the first gen Yaris/echo and the second gen yaris.
The intake for example is different. The exhaust manifold (header) is very similar between the 2 but there is a slight difference. So a first gen 1.5 yaris/echo header won't fit into a Second gen Yaris unit.
If you are looking for a header option for a first gen Yaris/echo, then you should look for the first gen scion xB and xA headers. Those will fit onto a first gen Yaris.
Old 11-11-2008, 05:58 PM   #22
rob323
What I was alluding to was that if the 1.5 Yaris came with a similar longer primary header than the 1.3 litre Yaris (as it did in the Echo), then that may be a cheaper option for the OP to look into instead of an aftermarket one.
I have a stack of assorted Echo parts, sadly no Yaris bits though to be able to thoroughly compare them.
Old 11-14-2008, 09:50 PM   #23
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
so...back to topic..
Therefore my setup would be 4-1 Headers ----> single cat--->mid pipe-->bolt on muffler?
harveyjai is offline   Reply With Quote
Old 11-14-2008, 10:20 PM   #24
CASTREX
CASTREX's Avatar
yeap!
Old 11-15-2008, 06:42 AM   #25
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
cheers,
just one more thing, wht that coating that u put on the headers that can smoothen the air flow inside? Would it be better if i do that instead of getting a new header?
Old 11-15-2008, 11:41 AM   #26
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
so i thought the header would give like 1 +whp. thats what i read a while back pre hack. does the mid pipe help that much? what can the expected gains be? and does it work with an axle back exhaust
Old 11-15-2008, 12:59 PM   #27
CASTREX
CASTREX's Avatar
Originally Posted by harveyjai View Post
cheers,
You probably are talking about a ceramic coating. A ceramic coating can be applied on the outside, inside or both of an exhaust manifold or header. The function of the ceramic coating is to contain the heat within the pipe. Is not used to smooth anyting out.
Yes is useful, the DC header comes pre-coated, but the idea is to minimize the heat disipation thru the pipe.
I don't think that no one has made so far any intensive back to back dyno testing of Yaris exhaust components.
There are no back to back testing of the different header options or how they work along with other exhaust modifications. So any answer to your question will be mostly expeculation.
So all the comments you hear come from personal opinions (butt dynos).
Old 11-15-2008, 03:48 PM   #28
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
ceramic coating..
Thats it!!
Would you apply them on everything?
or would it only be worth it to apply on headers?..umm..
Old 11-16-2008, 11:29 AM   #29
richardholdener
Drives: 2008 Yaris hatch
Just a note for this post-I am testing the true long-tube header on the Yaris today. If it works well, we plan on making a long-tube and complete 2.25-inch mid pipe exaust to go from header to axle back. We will also make an off-raod pipe to mate the stock shorty header to this exhaust as well. I'll post as sonn as we have dyno results.
richardholdener is offline   Reply With Quote
Old 11-16-2008, 11:37 AM   #30
now that's an awesome idea, richard fingers crossed!
Old 11-16-2008, 11:51 AM   #31
at3GG
at3GG's Avatar
Drives: 07 metmet LB
Richard just keeps it coming...
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 11-16-2008, 04:38 PM   #32
CASTREX
CASTREX's Avatar
ceramic coating..
Thats it!!
I will say only the header... you will have a hard time coating the rest of the exhaust as most of the ceramic coatings need some time in the oven to cure...
Old 11-22-2008, 12:49 PM   #33
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
Castrex, in your t-sport that's a round muffler magnaflow 5 inches?
t0m4s is offline   Reply With Quote
Old 11-23-2008, 12:59 AM   #34
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
custom is the way to go IMO, and if you delete the cats be sure to get a O2 simulater or build one with the proper ohm resistor.
i am running a custom catback set up...under $200US for everything. I have pics in my garage of part of the pipe work.
new 5zigen proracer exhaust 4 yaris laszlo Performance Modifications 13 08-16-2007 01:29 PM
