Old 11-07-2008, 08:51 PM   #1
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
Full exhaust System for NA yaris
Hi guys,
I just wanna know what would be the best combination of doing a full exhaust system for a NA yaris.
Atm, i have a bolt on muffler. I have read post saying Headers might not make too much difference. Also some of my mates told me to modify the cat or something.
What do u think is the best combination piping for a NA yaris? I wanna get the most out of my NA yaris...
I don't mine custom the whole thing, i just need some ideas.
Cheers,
Harvey
harveyjai is offline   Reply With Quote
Old 11-07-2008, 08:53 PM   #2
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
Garm ( cali yaris ) sell a nitto midpipe that would work for clearing the farts out the rear end
Thej3sta2 is offline   Reply With Quote
Old 11-07-2008, 10:53 PM   #3
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
so that is a midpipe with a bolt on muffler that you are suggesting?
Old 11-07-2008, 11:10 PM   #4
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
DC 4-2-1 Header + Nitto Midpipe + Fujitsubo Wagolis = Yes ?
PG TLD22 8V Line Driver
Old 11-08-2008, 02:24 AM   #5
^ ooh, nice
Old 11-08-2008, 10:58 AM   #6
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
if we custom the whole thing, should we only use one cat? or? get rid of the cat? or?..
Old 11-08-2008, 11:00 AM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
+1
I still haven't seen the DC 4-2-1 yet, but IMO 4-2-1 is the way to go for the Yaris. WSCP sells the W*R 4-2-1 header in case you're interested.
Old 11-08-2008, 11:11 AM   #8
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
some of my friends have told me to get the 4-1 for yaris...any reason y?
if u keep u rev above 3K, 4-1 is better or 4-2-1?
Old 11-08-2008, 11:35 AM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I've heard 4-1 is better for the higher range, and 4-2-1 is better for the lower/middle ranges.
Old 11-08-2008, 12:32 PM   #10
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
The DC header mentioned above is actually a 4-1 design. There is only one 4-2-1 header available for the Yaris and is from Weapon R.
In theory a 4-1 will provide a better gain and higher rpm while a 4-2-1 will provide better gains at the mid range. The problem is that by design the Yaris header is so short that I doubt there is much difference between any of the current model available. So I would tell you to choose the one that fits your budget!
If you want the ultimate set up and still keep it legal for emission testing I will tell you to get a high flow cat Only one or at least remove the secondary cat leave the primary cat. You already have a bolt on muffler so you just need the mid pipe.
If you can get mandrel bent tubing go for 2" pipe if you can't get it, then go for 2.25" pipe.
If you want it civil, snap a round mufller/resonator in the middle in place of the OE resonator and ou are good to go!
And the header will make some difference as long as you work out the rest of the muffler. Not much gain by mating a header with a stock exhaust.
Old 11-08-2008, 12:58 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interesting info! Thanks CASTREX
Old 11-08-2008, 08:25 PM   #12
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
i've heard that seddan 08 has 2 cats and there are 2 air sensors after each cat, when you do that mod above what r u gonna do with the sensors? it will not give u CE light?
i'm asking cuz i wanna do a mod almost like this
t0m4s is offline   Reply With Quote
Old 11-09-2008, 01:19 AM   #13
CASTREX
CASTREX's Avatar
Sedan = Liftback. The only difference is the axleback section. In the sedan is a little longer.
Both models come with 2 cat converters. First one just after the exhaust manifold and the other one a few inches after.
The car has 2 sensors on the exhaust the first one and the most important is in the header. You can not mess with that one. Then there is a second sensor right after the first cat. The function of that one is monitoring the functionality of the Primary (first) cat. That one can be easily tricked if you plan to go catless. There is no sensors after the second cat. Therefore you can remove that one if you want and your car won't even notice it.
Old 11-09-2008, 04:56 PM   #14
t0m4s
1NZ-FE
t0m4s's Avatar
so when i change the header i just need to leave the sensor where it is and replace the header?
Old 11-09-2008, 05:29 PM   #15
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Do you have the 1.3 litre motor or the 1.5? Do the primaries on your stock headers have the collector down at the flange or only half way down?
rob323 is offline   Reply With Quote
Old 11-09-2008, 11:39 PM   #16
CASTREX
CASTREX's Avatar
Yes. You just need to unplug the sensor on the stock exhaust manifold. Take the manifold out and install the header and finally put te sensor back on the header. It should have a bung for the sensor. Pretty simple
Old 11-11-2008, 08:15 AM   #17
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
The DC header mentioned above is actually a 4-1 design. There is only one 4-2-1 header ....
Cheers, that is some useful info there!
Old 11-11-2008, 03:21 PM   #18
rob323
Do your stock headers look like these from a 1.3 litre Echo?
Or like these from a 1.5 litre Echo?
A guy on Ozecho has swapped the 1.5 litre manifold (the one with the longer primaries) onto his 1.3 litre and is happy with the improvement.
new 5zigen proracer exhaust 4 yaris laszlo Performance Modifications 13 08-16-2007 01:29 PM
