Old 11-20-2008, 01:32 AM   #19
revoturbo
revoturbo's Avatar
Drives: yaris
my Yaris, zage turbo kit HP & torque
dyno test at Rev engineering Jakarta Indonesia.
.35 Bar when I used standard model muffler BLITZ NUr Spec..
when I use freeflow muffler much different!!
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 11-23-2008, 12:22 AM   #20
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
More info on this Piggy back system that works fine!
Old 11-23-2008, 06:07 PM   #21
revoturbo
revoturbo's Avatar
Drives: yaris
You can contact Teddy , REV engineering, he is the man build more than 10 zage turbo kit (yaris) & more than 10 of suzuki swift turbo/ civic too
all of them very satisfy with the results..
contact : teddyrev@yahoo.co.id
Old 11-23-2008, 07:54 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
"what's in the kit" has nothing to do with how much power it will make.. if the turbo is big enough, you'll make the power.. with boost turned up of course
Old 11-24-2008, 01:06 AM   #23
revoturbo
revoturbo's Avatar
Drives: yaris
with big turbo = big power = big turbo lag..
small turbo = enough power = low turbo lag = daily use no problem = save on fuel too
Old 08-11-2013, 04:53 PM   #24
Balal khan
Drives: Toyota yaris 1.3
Hi I just joined and I want to buy a zage turbo kit and was wondering if there is anything else I need.
I need gauges and I don't which ones i need apart from boost gauge and where is the best place to mount them
Balal khan is offline   Reply With Quote
Old 08-11-2013, 08:11 PM   #25
Wow, 5 year old thread. I sell the Zage kits here in the USA.
Recommended gauges besides boost are oil pressure and water temp.
You'll need to buy management so you can tune your motor as well; the Zage kit does not include engine management. I would also have a set of 1ZZ injectors on hand in case your particular tune come out too lean with stock injectors.
Let me know if I can answer any more questions for you.
Old 03-09-2015, 02:54 PM   #26
Zippy2004
Drives: 2004 Vitz/Echo/Pre-Yaris
Is there a zage kit for the 2004 echo? I am tempted to trade the echo in for a Mini Cooper just for the fact that I want some extra kick in my ride and I wouldn't have to mod the mini. (Already super/turbo charged) But I don't want to loose the reliability of the mighty yota!
Zippy2004 is offline   Reply With Quote
Old 03-09-2015, 03:24 PM   #27
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Whatever you do you would very well regret going with the Mini. They are about as reliable as dollar store toilet paper. If there isn't a Zage kit for the echo in your year you would probably only need to pick up a couple different sections of IC piping depending on spacial issues.
NST NonStopTuning Short Shift Kits NonStopTuning NonStopTuning 2 11-11-2008 07:39 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
TURBO DIY... forpinks Forced Induction Forum 33 09-06-2007 02:03 AM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
