Old 12-01-2008, 05:37 PM   #19
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Originally Posted by IllusionX View Post
how could they do more damages than good ? they are made so that OTHERS can see you are coming... otherwise, can you believe how many accidents happen in a dim morning? people don't turn on their light.. so you don't see when they are coming.
i say the biggest problem is the backlit clusters. They are always on, so you think your lights are on.
Exactly.
Old 12-03-2008, 09:07 PM   #20
WolfWings
WolfWings's Avatar
Yup, right there, the 'CP' package: Larger Washer Tank with Level Warning = Swallows 7-Eleven super big-gulps of washer fluid with ease. And the 'Heavy Duty Heater' is the ceramic heater module. =^.^=
Old 12-03-2008, 10:06 PM   #21
auxmike
auxmike's Avatar
Don't forget the heavy duty starter too!
A bargin for $110.......
Old 12-03-2008, 10:22 PM   #22
nemelek
DWEED
nemelek's Avatar
I forgot to turn on the headlights a couple of times. That's why I disabled my DRL. I figure that it is safer to always drive with tail lights on at night time than to drive with the headlights on all the time.
Old 12-03-2008, 10:54 PM   #23
auxmike
auxmike's Avatar
I got in my car last night and did almost drive off without turning on the headlights/tails.
It IS confusing since the gauges do light up regardless. BUT the A/C and temp controls don't, so that should be a hint that something's missing at night.
I've no plans to tinker with the DRL's though.
Old 12-04-2008, 01:40 AM   #24
WolfWings
WolfWings's Avatar
No 'tinkering' involved, just unplug the DRL module that's bolted to the drivers-side of the A/C control console just behind the dash, takes five minutes. Want em' back? Plug it back in, done.
Personally I have mine unplugged, and I keep my lights-dimmer just 'behind' the click to full bright, so my lights all dim noticably when I turn my headlights on. It's not much, but self-training to teach myself 'OMG Bright = No Headlights!' works better than you'd think. :-)
Old 12-04-2008, 12:33 PM   #25
TheSilkySmooth
TheSilkySmooth's Avatar
The cold weather pack can be easilly checked for in the US: Do you have a 'low windshield wiper fluid' light? You have the cold weather pack. It also includes a MUCH larger washer-fluid tank, able to gulp down an entire 1-gallon bottle of fluid from a gas station at a go once the low-fluid light turns on.
It also comes with a somewhat akward-to-utilize but awesome feature: The ceramic block heater. Turn on the car and leave it at idle, with the temperature at full, and you have positively scalding heat even with the engine bone-cold. :-) It's not mentioned in the owner's manual, but it's in the workshop manuals on what triggers it: Engine idle, coolant cold, ambient temperature under about 50F, you get artificial heating.
Really. I dont think I have this. In fact its a fire hazard - I dont know if anyone would have this on a US car. I have always WISHED cars had and electric element heater for deforst on icy vindeshieldt days. But Show me the money? This engine is warmed up in 3 minutes after start so unless its instant within ten seconds or so I still cant believe it.
Old 12-04-2008, 09:45 PM   #26
ToddR
Bacon!
ToddR's Avatar
Drives: 2008 Red Yaris LB
Fire hazard or not, it's there if you have the All-Weather Guard package. Here in the midwest cars don't warm up in three minutes during the winter. I'm really glad I have this in my Yaris, but I wonder if the high power consumption is effecting my mileage. It looks like it draws close to 40 amps when on.
FYI
The DRL module is also tied into the foglight wiring. I seem to recall a user here who had some issue with his foglights after removing the DRL module. The post may have been lost in the hack and I can't recall what the exact problem was (and I'm too lazy to look for it) but it's worth mentioning.
Last edited by ToddR; 12-05-2008 at 06:16 AM. Reason: typing with mittens on does not work
ToddR is offline   Reply With Quote
Old 12-05-2008, 05:02 AM   #27
Jerkratt
Jerkratt's Avatar
just have to find the wire that grounds out the fog lights and splice tgem together or insert into harness and tape/soder
"It hurts more when its wet"
Old 12-05-2008, 08:19 AM   #28
WolfWings
WolfWings's Avatar
Hell, I'm lucky to get my Yaris to turn off the 'cold' marker in ten miles of driving in the winter out here in Missouri. But if I let it set 10-30 seconds before I leave, the ceramic block heater's warmed up and I get warm air at least even if the engine is cold.
And it's actually not a fire hazard. While it can pump out 'hot to the touch' air, it can't make enough heat to actually catch things on fire AFAIK.
Old 12-05-2008, 11:03 AM   #29
Wait till someone runs into your one a not so bright day. I've almost backed into this 90 integra that always drive by when i go out in the morning... At a glance, it looks like just like any other car parked on the street without the headlights on (DRL) as it's not dark enough to actually turn on the headlights.
Besides...there's a light in the cluster that tells you if your tail lights are on or not. I'm also wondering how could someone drive 30hours without even looking at ANYTHING else than the cluster ?? I mean, don't anybody have to tinkle with the HVAC during a couple hours of drive ??
Old 12-05-2008, 01:03 PM   #30
TheSilkySmooth
[QUOTE=ToddR;190608]Fire hazard or not, it's there if you have the All-Weather Guard package. Here in the midwest cars don't warm up in three minutes during the winter. I'm really glad I have this in my Yaris, but I wonder if the high power consumption is effecting my mileage. It looks like it draws close to 40 amps when on.=QUOTE]
Well, I am in the cold New England and we are regularly +20 deg F and have a week of -10 to -20F usually once the season. I have the optional Cold weather package with HD heater and big washer bottle and heavy fan. So How do I get this special heat t work? Where exactly do you set the HVAC controls - maybe this is answer mystery why my car dies with the heat on - electric heater its taking all the juicyness far away away from my little battery
Old 12-07-2008, 08:18 PM   #31
metalshark
MetalShark
Drives: 2008 Yaris LB
Forgetfull?
Yup, I'm old. I deal with it. On my Chevy lumina there is a photocell somewhere that prevents a driver, seeing DRLs, from driving at night without tail lights. The switch to a new Toyota threw me. I drove the lumina for 10 years. Rather than try to teach an "old dog" new tricks I just pulled the DRL relay. I'm writing out my will and have forgotten your name.......maybe it will come to me. Hell, if I'd taken my Ginko I could remember where I hid the Viagra.
End of problem.
Originally Posted by MUSKOKA800 View Post
So...you disabled a safety feature for safety reasons (because you're forgetful).
Are DRL's not mandated in AZ? They are here in Canada, and have been since the 80's.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 12-07-2008, 08:29 PM   #32
metalshark
MetalShark
After 24 hours of driving you pull off into a parking lot and jack the seat back for a 30 min snooze. It'l perk you up just enough for that last fifty miles without putting it in the ditch when you fall asleep. When you wake up you can drive but Sherlock Holmes you ain't.
Old 12-07-2008, 08:52 PM   #33
WolfWings
WolfWings's Avatar
Well, I am in the cold New England and we are regularly +20 deg F and have a week of -10 to -20F usually once the season. I have the optional Cold weather package with HD heater and big washer bottle and heavy fan. So How do I get this special heat to work? Where exactly do you set the HVAC controls - maybe this is answer mystery why my car dies with the heat on - electric heater its taking all the juicyness far away away from my little battery
The car must be:
A/C Temperature at MAX.
Blower is anything but off.
Engine at idle speed or faster, AKA running!
Outside air is 50F/10C or less. (Cold enough to fog the windshield.)
Coolant is 150F/65C or less. (Cool light is still lit on the dashboard.)
It will turn the ceramic heater on in stages at 10, 20, and 30 seconds, ramping up from 20 amps to 30 amps, then 40 amps. So it's not a sudden 'surge' of hot air, but it does warm up quickly.
The effect will be most noticable if you keep the blower on LOW, not high. Set the 'vents' to the far left/dash-only, close everything but the side vent on one side, aim it at your face, set blower on low, near-instant toasty.
Old 12-07-2008, 10:01 PM   #34
auxmike
auxmike's Avatar
Nice!
I gotta try this!
Old 12-29-2008, 11:06 PM   #35
chucksmaster
Drives: 08 butt white hb plain jane
I would agree with most everything being said about the benefits of DRLs. Now for the disadvantages as I see them.Drivers in America are going to get lazy and only be looking for a light coming down the road as more and more cars are equipped with them. This could potentially cause accidents. Another disadvantage is these are your low beams when your lights are on so instead of getting years and years of service from your bulbs you will be getting about 3 years out of your expensive halogen bulbs not to mention the pain in the rear of changing them more often and the possibility of driving around with a burned out headlight and not knowing it until the law pulls you over and hands you a ticket. These are just some observations from driving my 02 Passat for 7 years.
chucksmaster is offline   Reply With Quote
Old 12-31-2008, 01:55 PM   #36
ToddR
Bacon!
ToddR's Avatar
$8.99 each (@ Napa) is really not that expensive, but changing them is a pain in the butt.
Manual Transmission...Safety Issue!!! twocvforme General Yaris / Vitz Discussion 189 10-30-2010 11:00 PM
RS stock page alert question.. marcus Cosmetic Modifications (Exterior/Interior) 15 11-21-2008 09:09 AM
EBAY Seller Alert for Yarisworld Members redyaris DIY / Maintenance / Service 29 07-02-2007 09:23 PM
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 10:21 AM
