#1 |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Safety, Critical Alert
I got a warning ticket from Arizona DPS for two reasons. 1) I'd been driving for 30 hours. 2) The day time running lights on my '08 HB don't turn on the tail lights.
After my second pull-off nap on the way home I started the engine, the day time running lights kicked on and I didn't notice that the lights on the radio and heater controls weren't on. That would be the tired drivers clue that the tail lights weren't on. I signed off on the citations corrective action block after I had down loaded the DIY on disabling the daytime running lights and had pulled the connector plug off of the relay inside the dash. Now when its dark enough to see headlights I have to turn on the lights. No head/lights and/or tail lights on is the LEO's most often probable cause for a DUI check. Luckily all my paper work and permits were in order. Moderator, please bump and/or sticky.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
Drives: lil red 5-door Join Date: Sep 2006
yeah that is one of the pitfalls of DRLs... Heck even without them, in a well-lit city, it's easy to forget to turn on the lights at all
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#3 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Daytime running lights dont usually include having the tail lights on at the same time.This cop you ran into sounds like he wasnt up on his facts . and how did he know you were driving for 30hrs?you didnt tell him did you?,actually its only truck/commercial drivers who are compelled to drive only a certain number of hours a day,So his warning was probably more a suggestion to get some sleep and his take on no tail lights with the drl's was probably just an observation, of course if its night time you have to turn on your headlights to get the tail lights working.
#4 | ||
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
![]() Quote:
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
So...you disabled a safety feature for safety reasons (because you're forgetful). ![]() Are DRL's not mandated in AZ? They are here in Canada, and have been since the 80's.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#6 |
i set up my tach light to come on with the headlights,this helps me never forget.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Your 08 HB has DRLs? Mine doesn't! I was wishing I had them, as my last car did; but now I am thinking it may not be the greatest option on the car.
And, of course, there is that little light on the instrument cluster when the lights are on! Cheers! M2 |
#8 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
they aren't standard???
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
Good reason not to start screwin' around with safety features.
![]() I love my DRLs
#10 | |
Also, I suppose you have to weigh the risk of being rear ended because you didn't turn on the lights due to the headlights being on. I know I've forgotten to turn the lights on because I could see in front of me and read the instrument panel. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I remember pre-hack someone mentioned that DRLs in the U.S. came with some kind of cold weather package. Not quite sure what is in a cold weather package. A sweater?
My Californial LB did not come with DRL.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#12 |
The cold weather pack includes the rear wiper, a bigger starter, rear window defrost, and a couple of other little odds and ends. My wife and I bought our Yarii in NYC, so the cold weather pack was almost standard equipment.
#13 |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
The cold weather pack can be easilly checked for in the US: Do you have a 'low windshield wiper fluid' light? You have the cold weather pack. It also includes a MUCH larger washer-fluid tank, able to gulp down an entire 1-gallon bottle of fluid from a gas station at a go once the low-fluid light turns on.
It also comes with a somewhat akward-to-utilize but awesome feature: The ceramic block heater. Turn on the car and leave it at idle, with the temperature at full, and you have positively scalding heat even with the engine bone-cold. :-) It's not mentioned in the owner's manual, but it's in the workshop manuals on what triggers it: Engine idle, coolant cold, ambient temperature under about 50F, you get artificial heating.
#14 |
Here's the details right off my build sheet;
PS: the power pkg. is worth every cent... |
#15 |
![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
I hope people aren't confusing DRL's with auto-lights. My old grand am had drl's like everybody else, but, headlights would kick on automatically when it got dark enough, now those I can stand. DRL's I hate, I think they do more damage then good. Of course I keep my dash cluster turned down so it's at it's dimmest light, so if the dash lights start bothering me, I know my headlights aren't on.
#16 |
I agree with dybbuk, DRL's by themselves do more harm than good because they teach you to ignore your lights, but don't turn on the most important ones, proper headlights and taillights, at night. Actual fully-automated headlight systems? Those I have no problem with.
#17 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
how could they do more damages than good ? they are made so that OTHERS can see you are coming... otherwise, can you believe how many accidents happen in a dim morning? people don't turn on their light.. so you don't see when they are coming.
i say the biggest problem is the backlit clusters. They are always on, so you think your lights are on. |
#18 |
a good habit to get into is turning your lights on EVERY TIME you get in your car, day or night.. DRLs save lives. i agree, having DRLs suck (i disabled mine in my corolla) but having your lights off raises your chances of getting pulled out in front of or cut off, even during the day. this goes especially for black/grey cars..
and please, no one say you're doing it to save electricity/gas mileage lmfao |
| Manual Transmission...Safety Issue!!! | twocvforme | General Yaris / Vitz Discussion | 189 | 10-30-2010 11:00 PM |
| RS stock page alert question.. | marcus | Cosmetic Modifications (Exterior/Interior) | 15 | 11-21-2008 09:09 AM |
| EBAY Seller Alert for Yarisworld Members | redyaris | DIY / Maintenance / Service | 29 | 07-02-2007 09:23 PM |
| Turn signal audible alert | paultyler_82 | Performance Modifications | 7 | 10-01-2006 10:21 AM |
