#19 |
3,300+ at one point.. >:(
Drives: 2010 Hatchback RS Join Date: Aug 2007
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
#21 |
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Since I posted the initial question on both the "New Yaris Owner" and "Fuel Economy" forums (this is called cross-posting), I also posted the answer to the problem in both.
At least I HOPE that's the answer to the problem. Okay; no more picking on the Yaris! This was "pilot error," so we start with a clean slate. Cute little Yaris!!! |
#22 |
![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
#23 |
#24 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
lol
hey.. the 3rd and 4th are not indented? I had driven my sister's camry a few times.. and the 4th and 5th are in horizontal. You would pull it down and it's 5th, and push to the left and it's 4th.. btw, for the automatic drivers... all automatic yaris have this set of lights in the cluster that tell you which gear you are shifted to. :) |
#25 | |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
don't feel like ...
#26 |
Yea, I'm Awesome
Driving in 3rd, FTW... wait, ftl!
I am glad your gas millage mystery has been solved, and it was nothing that was bad.
Meg
(+410 posts prior 10/18/08; Real Join Date: Jan 2008) "Haha i would never call your car conservative." Richie Perrette |
#27 | |
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
I like the design of the a/t shifter. You can tell which gear you shift into when pretending to be a manual without accidently shifting into neutral! Glad you solved your problem though.
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
#28 |
Albino truck smasher
Drives: '07 Yaris LB Auto Join Date: Oct 2008
Haha that happened to me in the first few days of ownership. "Why is the engine so damn loud at highways speeds?" It wasn't until I looked in the manual that I figured it out. I was even a bit scared that I might damage the car by shifting into 4th.
![]() That's what happens when you are so used to driving stick that all those little grooves on the Auto confuse the hell out of you. |
#29 |
I really LOVE this car!!!
Drives: 08 Bayou Blue LB AT Join Date: Oct 2008
Was not my problem. Was otterhere's.
My salesman did not take the time to explain it to me though. Luckily I already knew. Actually, I had to show him the sliding fold flat rear seat thing. They were clearly no very educated on the Yaris. |
#30 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
who me? Idk how I do... it just happens some times. I usually end up knocking it out when i reach for something. its not like it happens a lot, im not that silly. Its scary enough the first time you accidently do it... it doesnt need to be repeated.
#31 |
Actually, guys, I just noticed that when the car's in P (park), the stick is all the way over to the left. You actually move it up and OVER to get it there; the opening is double wide like the opening in the 3-D slot, unlike the others.
Quite likely I made the unconscious association when it came to the 3-D and just assumed I needed to have it all the over the left here, as well... Again, without thinking too hard about it, obviously, but there were so many other things new and different to get used to that I probably just figured, well, if it goes, all is well, but da*n that engine is loud, and why such lousy mileage? Okay; if everyone's done razzing me, we can move on to another topic now.
#32 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Yes, lets.
At least now we have another "obvious" question to ask the next person who is exasperated with a low mileage yaris.
#33 |
Drives: lil red 5-door Join Date: Sep 2006
oops didn't see there were two threads... problem solved!
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Toyota Yaris achieves over 84 mpg in MPG Marathon | tk-421 | Off-topic / Other Cars / Everything else Discussions | 5 | 11-17-2008 07:41 PM |
| Toyota Yaris MPG Review at www.mpgomatic.com | aca72 | Fuel Economy Forum | 23 | 10-31-2008 03:59 PM |
| Am I calculating MPG correctly? | YarisBlazer | General Yaris / Vitz Discussion | 24 | 08-18-2007 11:57 AM |
