Old 12-30-2008, 02:38 PM   #19
ddongbap
Nobody just curbs their car?
Old 12-30-2008, 03:04 PM   #20
MUSKOKA800
MUSKOKA800's Avatar
I use ramps. Between the front lip and lowering springs I need the clearance to work the wrench and have room for catch pan. Plus while up on the ramps the oil pan is tilted back toward the drain for a quicker, more thorough dump.
Old 12-30-2008, 03:16 PM   #21
gid
Drives: '08 Yaris sedan , '08 Liftback
or ...
Originally Posted by gid View Post
go to , http://s49.photobucket.com/albums/f2...0Oil%20Change/ . Click on images for a look . Nice 1st generation XB too . Kin to the YARIS .
could just use use layer of 2" ( H ) x 10" (or 12") (W) x 36" ( L ) . Be easier for car to climb and oil pan be angled . Better yet , use 1 board of 1 level under 1 or both wheels on drivers side . That way pan be sloped for better drainage . Hope I'm not confusing you to much .
gid is offline   Reply With Quote
Old 12-30-2008, 03:17 PM   #22
xpeteyjtx
Drives: 07 BB Yaris
Originally Posted by Rich k View Post
What brand / types of pan to drain the oil into fit under the yaris w/o jacks ramps?
My pan has a maximum height of 4.5". You have to loosen the drain bolt with a wrench, then remove it with your left hand, while using your right hand to maneuver the pan under the bolt.
xpeteyjtx is offline   Reply With Quote
Old 12-30-2008, 04:16 PM   #23
Chupacabra
Drives: 2009 Yaris liftback
I have DF210's and can do it w/o any problem. No ramps...no boards. I have the fujitomo valve installed but it's not necessary in any way. Just handy to have a ball valve drain system. No tools needed to do an oil change. Hand tight filter and ball valve drain.
Chupacabra is offline   Reply With Quote
Old 12-30-2008, 04:19 PM   #24
YAR1S
YAR1S's Avatar
I use ramps...
-Jen <3
Old 12-30-2008, 06:51 PM   #25
sportin83
Drives: 2008 blazing blue yaris LB
i just changed mine 15 mins ago and i didnt use a jack and i am 6'5" and round 240. i just twist filter loose stick pan under and pull bolt out and let it run. its simple takes longer to let oil drain than to actually get bolt and filter out.
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 12-30-2008, 08:46 PM   #26
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Ice cream bucket and a 2x4 under each front wheel works fine with my 1.5" drop in the springs.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 12-30-2008, 08:52 PM   #27
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i did my oil change lowered with df210 springs without a jack.
Old 12-30-2008, 10:51 PM   #28
gid
you sure you're not milking a cow ?
Old 12-30-2008, 11:05 PM   #29
gid
A 2"x4" under each front wheel sounds a bit dangerous . You starting a new X-treme sport ? 1 under each tire on drivers side might be less dangerous , plus help oil drain better since the oil pan is sloped toward the passenger side ( right ) . Hope you use bricks , rock , piece of scrap wood , or a gold bar behind each wheel .
Old 12-31-2008, 12:02 AM   #30
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Floor jack is the solution to all!!!! Plus I cant get to my filter without it!
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 12-31-2008, 02:30 AM   #31
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I use store bought ramps. It's safe and easy to drain and change filter. They go on sale for about $14.00.
Old 12-31-2008, 02:47 AM   #32
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Originally Posted by rningonfumes View Post
You have the valve? Did you need to put anything around the threads? Waiting for my next oil change to put it on.
Yes, and no. Buy the correct one and its a direct fit. The lever might not be oriented exactly how you like it but when I want to drop my oil I'll just rack my steering all the way to the right side and my hand can easily reach in the gap to get the valve.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 01-01-2009, 03:11 PM   #33
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
Here they make you take it to the dealers for an oil change, although I wish I could do it myself. Have no hand on experience with cars, whatsoever.
EDIT: and they charged me 22$
ZING is offline   Reply With Quote
Old 01-01-2009, 05:04 PM   #34
cleong
cleong's Avatar
I've thrown my packaging away but based on Fumoto's chart, F-103 would be it. But I would email them to make sure, though.
TRD Blue brake pads
DC Sports header
Old 01-02-2009, 12:52 AM   #35
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
The yaris oc is simple,as everything is right up front.
15 mm socket is the only tool required.
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
Old 01-02-2009, 08:06 PM   #36
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I do. I jack the driver side a little just to squeeze my big head underneath of it even though its not completely safe.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
